Quattro john
I have a 1999 A4 avant 2.5tdi v6 and have been having some problems in the recent cold spell with regards starting. The glow plug light comes on as normal,then goes out but it doesn't start for a few turns,as if the glow plugs are not working.On checking the plugs there were 4 not working so i replaced all 6.However its still the same.The local audi garage said after checking it out that it was the coolant temp sensor. So i got that and replaced it but still the same.I have checked the glow plugs again and there fine but there is no feed to the wiring for the glow plugs.So i wonder if anyone has had a similar problem or can tell me where the relay is,so i can check that.
Many thanks John.
Many thanks John.
