Boot unlocking problem
redbutcher
Northants
Bit of a problem which I hope someone can help me with.
At the moment I don't have selective unlocking enabled in vag com. When I unlock the car from the remote, all the doors unlock (front and rear) but the boot stays locked. I can't even open the boot from the latch button. I have to use the middle remote button and it's a real pain.
The latch button is working fine as if I open the boot and press the button you can hear the mechanism working.
I've tried enabling selective unlocking in vag com and that's not working either - it just unlocks all doors, no matter what the setting is in vag com.
If I measure group 4 in channel 46 it shows the rear lid button as being non operational.
What I'd like to happen is that when the car is unlocked from the remote, all the doors and boot are unlocked so I can open the boot from the latch button and not have to use the middle button on the remote all the time. Hoping someone can help me out as it's really doing my head in!!
Hi Uwe,
As requested:
VCDS Version: Beta 803.1
Data version: 20080309
Sunday,16,March,2008,14:05:24:56737
Chassis Type: 1K0
Scan: 01 03 04 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72
VIN: WAUZZZ8P28A100672 Mileage: 9020km/5604miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LG HW: 03G 906 021 AN
Component: R4 2,0L EDC 000SG 9828
Revision: --H07--- Serial number: AUX7Z0GNFN105J
Coding: 0000072
Shop #: WSC 66565 257 00032
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 06314 000 00000
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
Component: KlimavollautomatH19 0420
Revision: 210010 Serial number: 8P0820043AG
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007817394
Coding: F58A1F01B01410004F1600001600000000094E175A050000000000000000
Shop #: WSC 06314 000 08192
Part No: 8P2 955 119 E
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Part No: 4E0 910 557 B
Component: REGENLICHTSENSORH13 0100
Coding: 00150573
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CP001HYSY
Coding: 0071612
Address 16: Steering wheel Labels: 1K0-953-549.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000012
Address 17: Instruments Labels: 8P0-920-xxx-17.lbl
Part No SW: 8P0 920 981 K HW: 8P0 920 981 K
Component: KOMBIINSTR. VDO H20 0640
Revision: D0H20001 Serial number: 224NG001101671
Coding: 0004429
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07A310012
Coding: E9817F064002020103
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H20001 Serial number: AUX7Z0GNFN105J
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 L HW: 8P0 035 192 L
Component: RNS-E HIGH EU H74 0650
Revision: 04S Serial number: AUZBZ7G0019665
Coding: 0209113
Shop #: WSC 44946 134 86300
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 101
Mileage: 5320 km
Time Indication: 0
Date: 2008.02.15
Time: 12:01:11
Freeze Frame:
Mileage: 5320 km
Count: 1502
Clock: 12:00
Address 42: Door Elect, Driver Labels: None
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H03 0050
Coding: 0004856
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1800020000407F3F85054C9FC230
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 52: Door Elect, Pass. Labels: None
Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
Coding: 0004856
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000001
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209113
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 101
Mileage: 5320 km
Time Indication: 0
Date: 2008.02.15
Time: 12:01:11
Freeze Frame:
Mileage: 5320 km
Count: 1502
Clock: 12:00
Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000216
Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000216
End ---------------------------------------------------------------------
Went through your scan but the only thing related to your trunk lid problem could IMHO be the real lid security lock mentioned in the coding. As far I understand what you are saying, it could be the button/micro switch being faulty.
Regarding the selective locking you are trying to enable, there are 3 instances where this can be enabled. The coding, the adaptation channels and last but not least the DIS menu in the instrument cluster.
Thanks for the info Sebastian - I'll take a look at the security lock setting in the long coding and will go through the adaptation channels. Failing that it will mean a trip to the stealers I think.
Will post back if i get anywhere.
Quick update - selective unlocking is now working properly - I set it via the DIS (I didn't know you could do this - much easier!). Also looks like you can set the window convienience closing settings using the DIS as well.
Will hook up vag-com tomorrow morning to see if I can sort the boot unlocking issue.
Right, have disabled the security lid lock in the coding, and still the boot won't open unless I use the middle button on the remote - really weird.
Will see if there is anything in the adaptation that might sort it at some point.
Sebastian, link to the control module maps below as requested.
Clicky
You're right there isn't any adaptation :sm4:
Just a bit annoying that I can only use the middle button on the remote to open the boot - oh well, next time it's in at the stealers I'll get them to take a look.
The micro switch works fine when the boot is open, just doesn't do anything when the boot is closed.
no tony i believe that is talking about synching a new remote to the car altogether not matching different buttons.
Ben
My car has been in to the dealer today and it was a coding issue that was causing the problem which is now fixed - hooray!
I'll do another scan of the car when I get it back to show the new coding :thumbsup:
Forgot to post the new coding which solved my problem:
Coding: 1880202002186D0885054C8FC637
Shop #: WSC 00443 210 91141
