S4 vs A3
stugolf
Hi guys, I currently have a Audi A3 3.2 Q DSG and I'm considering an S4 V8, in "real world" performance does anyone know how the S4's 344bhp compares with the 250bhp of the 3.2 V6?
Thanks, I've attached some pics as well
Well if you look at the numbers, your A3 has 247hp and weighs 1495kgs, giving 167hp/ton
The S4 has 340hp and weighs 1700kgs giving 203hp/ton
So in a straight line the S4 should be significantly quicker (Theoretical 13.8sec quartermile vs 14.6 for the A3)
As for handling, well the S4 is a heavier car which will detract from it a little, however it does have a better suspension design as far as i know (A3 uses mac struts?) which will help the S4 a bit. I'd say that unless your pushing it to the very limits of grip they should be pretty similar, although the longitudinal design of the S4 means it will feel a little more nose heavy compared with the A3
All round the S4 should be a better package. Might be worth getting a test drive to see if its right for you though...
