AdamXR340
Hi everyone, this will be my first post on the site so thank you in advance to anyone who can help.
My car, a 2008(57 plate)Audi A4 Avant B7 2.0 TDI with engine code BRE. I'm currently facing issues of boost/air flow issues.
Issue:
With All electrical sensors connected, the car is extremely underpowered, however does sometimes(unable to replicate) spring back to life and have full boost.
What steps I've taken:
I first purchased OBDEleven pro pack, I was using this to clear codes and see live data. I could see, using live data, the boost pressure actual and specified. When the car is not working correctly(issue above) the specified boost pressure remains sort of capped, no matter how much I put my foot down, it hangs around 1570mBAR and the specified follows suit. When I let me foot off the accelerator, the specified goes down as does actual. However when the car springs into life, now this could be at any point at any throttle position, the specified will increase as normal as will the actual.
Now, I've also looked at the MAF sensor readings and found the, when the issue is happening, the MAF sensor live data appears capped, same as the boost pressure. Same again, when it springs into life, the MAF reading shoot up in a normal manor and the car pulls away.
990
With the car being fairly dangerous being how slow it is when the issue is happening(90% of the time) I decided to unplug the MAF sensor, this would also act as another test. The car, with the MAF unplugged, works fine, boosts fine etc etc. It does run lumpy and not as powerful but this is to be expected, the key point I'm making here is that the car boosts and responds to my inputs just fine with the MAF unplugged.
I have tried 1 new MAF, cheap one, and 3 used but tested and working Bosch MAF sensors, the issue is still present in all tests.
I have tried a new MAP sensor, same issue.
The EGR is blanked off but not mapped out. - - - I have a new remapped ECU which I need to install but wanted to get this issue sorted first
I have just bought a Bluetooth multimeter to test the wiring for the MAF sensor with some wire piercing probes. The reason for the Bluetooth is the car appears fine at stand still but the issue is present when driving so would be good to see MAF voltages when driving.
Forgot to mention, no fault codes are logged when the MAF is plugged in. Only one that comes up is the EGR fault which is due to it being blanked off.
I will get a video of the live data and show what I mean because I don't think I explained it well
Issue:
990
