Kris6383
Ze germans are here
Hey everyone! What benefits can I gain from a smooth airbox and a 007 dv on a standard 1.8t? And what's the crack with drilling holes in the airbox? All help appreciated thanks
Uprating the DV is a worth while thing, especially if you're getting or running a remap but drilling the airbag is a waste of time.
Damian @ DPM Performance
How big of a hole and where?i drilled my airbox just for the induction noise (dont drill hole too big or have loads of them either), no gains what so ever from it
wouldnt it suck hot air from the engine though?A few 8mm holes on the side closest to the wing. Theres a few pics on google
Air is 150 odd degrees coming out of the turbo so irrelevant... thats what a decent intercooler is for
So why do we have cold air feeds and heat insulating air boxes even around cone induction kits ?
what cone filter is best? I heard jetex for audi.pro - a little induction noise
con - lot of effort for a little induction noise
Fit a cone filter... be happy
what would you suggest with fitting the cone filter? Taking airbox out completely, or cutting the airbox for the cone to fit in side?The most important thing is to make sure it's not oiled.
S2000 is tested and proven + cheap, or jetex as you said
excellent mate thank you. But.... What about it sucking in heat from the engine as people keep telling me.Removing the airbox completely. Then make a bracket our of some strip metal to stop the cone flapping about. If you keep the airbox on, you wont get any more induction noise.
Alternatively you can buy a heat shield to hold it in place
thanks mate.the air coming out of the turbo is going to be 100+ degrees regardless of its temp entering the turbo. don't be worried about it, you will gain power from fitting the pod.
If you are worried about it, fit a heat shield
any pics of your setup pal? And what s2000 filter? Looked on flea bay and there's a few.I've used an s2000 filter and left the bottom part of the airbox in, couple of cable ties keeps it nicely in place.
wicked thank you very much shall be getting one I think, how much did urs cost?View attachment 60192 White and red one, then painted it black so it matches evrything.
