034 Motorsport ARB - Rear Anti-Roll Bar
Bazgti
Can anybody explain why this mod is needed? And what it does? Cant ever say ive had to change the ARB on any car that ive had.
45bvtc
The Older I Get The Better I Was
Supporter
Gold Supporter
It is not 'needed' but for sure makes a 'positive' difference to the 'turn-in' of an 8P platform.
Does BLUEY have one fitted? Oh yes...
But then again I ran BLUEY in STD form first, did my own evaluation, and then made the changes needed to suit my own style of driving.
:racer:
Bazgti
:racer:
Ive only really driven mine for a few hours before disaster struck the next day. Its been sat on the drive since. Looking at the standard ARB though, its corroded to feck. The car was registered in not so sunny Scotland. My 25th anniversary was from there too and was the same kinda condition underneath. I may replace soon anyway. Just for a bit of bling
45bvtc
Supporter
Gold Supporter
Put it this way, I've fitted several 034 ARB's to 8P RS3s and no one has wanted to change back to the standard ARB:
It is the first thing I'd change - let's say way more of an improvement than 8.5J front rims, and I've done that too... :racer:
45bvtc
Supporter
Gold Supporter
The 8P RS3 is a GREAT car, stick with it. As with others you've collected the previous owners issues, sort 'em an enjoy.
Oh, and tyre pressures: 39psi front and 37psi rear works best and gives 'even' wear across the full width of the tyre - plus a tad more cushioning...
AND for "just for a bit of bling" on the rear discs, as you seem to be changing those too, see the drilled ones from MTEC - if only to match the fronts (doesn't improve the braking, mind...):
But I do have a low miles pair of original rear discs (no lip, no rust) if of use, probably pads too:
45bvtc
Supporter
Gold Supporter
I no longer need the forum....
John you are officially my new best friend! Haha You appear to be the oracle on the RS3!
Shhh
bobby_s3
Finally fitted my 034 rear ARB today after buying it 2 years ago .
Those drop link bolts were a bit tricky, as they were stuff!
Definitely feel the difference straight away, I put it on the stiffer setting as well
