- Joined
- Jun 24, 2010
- Messages
- 1,417
- Reaction score
- 241
- Points
- 63
- Location
- East Manchester In the Hills !
So after buying the Mrs a 2010 Golf GT 3 months ago for her 40th, she now tells me she hates it and wants her old Audi back. Erm - we chopped it in love !!!
So been to look at a few Black Editions and very surprised at how many dealers want to sell ex fleet dogs in my opinion which are all quite tatty and just been tarted up to make a quick buck.
However all is not lost and I have a found a 2009 BE 2.0 TDI with 38K on the clock and FASH which looks very clean and only has a few niggles with it like a broken air vent, broken battery cowling, arm rest lid clasp, tatty door seal and air bag light surround which is loose.
I gave it the obligatory scan with VCDS and it has quite a few errors which I was surprised at and the list was quite long. i.e. passenger door module, brake lights, radio, bulbs. However after clearing them all it looks like it has an issue with the MAF (No Biggie and an easy fix), the stereo doesn't seem to be coded right and error 00470 which from my research could be anything from door locks, battery drain broken wiring etc.
CDS Version: Release 12.12.2 (x64)
Data version: 20140212Tuesday,29,April,2014,11:27:08:34095
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WAUZZZ8P19A103483 Mileage: 63220km/39283miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 LS HW: 03L 906 022 BQ
Component: R4 2,0L EDC 0000SG 3610
Revision: 13H01--- Serial number: AUX7Z0I0FNF0F0
Coding: 0000072
Shop #: WSC 83968 666 461638
VCID: 810F6988D88CA516149-80D4
1 Fault Found:
000256 - Mass Air Flow Sensor (G70)
P0100 - 000 - Supply Voltage - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 115 /min
Speed: 0.0 km/h
Voltage: 6.54 V
Load: 100.0 %
Load: 100.0 %
Mass Air / Rev.: 805.0 mg/str
Mass Air / Rev.: 920.0 mg/str
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 13424012092200FDC80F02EC901C00823800
Shop #: WSC 06314 000 00000
VCID: 74E1B05CD73E00BE8FF-8021
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000217 Serial number: 8P0820043BG
Shop #: WSC 00000 000 00000
VCID: 72EDB6446D2A0E8E9D3-8027
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009290528
Coding: 118A0F81B0141380EF00000A0000000000084E0564060403642000000000
Shop #: WSC 06314 000 08192
VCID: 489934AC3B36D45E137-801D
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003CA004HTE3
Coding: 303142383038303030374A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 499F31A8E83C2D560C9-801C
Crash sensor for side airbag; driver side:
Serial number: 3572DRB4000087BD293$
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB4000087B9415W
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB400004986388L
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB400004985BC9Y
Crash sensor for front airbag; driver side:
Serial number: 35547RB400005F2A800K
Crash sensor for front airbag; passenger side:
Serial number: 35647RB400005F2A86A.
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002012
VCID: 418F2988180CE516D49-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H19 0860
Revision: D0H19007 Serial number: 2240I007013999
Coding: 0004428
Shop #: WSC 00568 210 80708
VCID: 397F416870DCBDD69C9-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K0911901EE
Coding: E9817F06000202002103
VCID: 377B475046C8ABA66AD-8062
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 110
Mileage: 63220 km
Time Indication: 0
Date: 2014.04.29
Time: 11:26:42
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H19007 Serial number: AUX7Z0I0FNF0F0
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000692
VCID: 438323800210F706C65-8016
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 233 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C51683C8F8E187E17F-8079
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D0985054C9FC637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000692
VCID: 4481209C071EF03EFFF-8011
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000013
VCID: FAFD1E64B55AF6CE553-80AF
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H03 0270
Revision: 00H03000 Serial number: AUZ1Z3I9720240
Coding: 0310201
VCID: 3F8B2F706EF893E6A2D-806A
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 15
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 428D26841D0AFE0ECD3-8017
End ---------------------------------------------------------------------
I really don't want to buy a lemon and have long term issues with it as this is not a cheap car. I wished I had saved the scan prior to clearing the codes.
Everything seems to work on the car, radio, locks, lights (number plate light blown) Air con etc and drives fine.
Any advice appreciated people. This is the 5th BE I have looked at and the cleanest straightest example yet, but these codes are worrying me. I don't know if the 00470 is related to the radio possibly not being coded correctly.
Coding: 0000072
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 115 /min
Speed: 0.0 km/h
Voltage: 6.54 V
Load: 100.0 %
Load: 100.0 %
Revision: 00H35001
Coding: 00056595
Shop #: WSC 06314
Coding: 0002012
Coding: 0004428
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 110
Mileage: 63220 km
Time Indication: 0
Date: 2014.04.29
Time: 11:26:42
Coding: 0000692
Revision: 00H15000
Coding: 0000692
Coding: 0000013
Coding: 0310201
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 15
Coding: 0000144
Coding: 0000144
