A few questions for those in the know with experience. I am rebuilding my TT engine. Initially I was going to keep the original pistons, they looked good and the bore appeared good. The engine had pretty good compression and no issues .
@Prawn convinced me that I would be better off replacing them as I am not likely to get the best out of the engine and somewhere down the line I am more likely to have issues.
So ordered a set of Wossner 82.5mm 9.5:1 pistons which then throws up a few more issues.
Does anybody know of an engine reconditioners that they can recommend in the West Midlands , Stafford area. To rebore the engine.?
Any tips of bore size and the hone, or just go with what Wossner say.
I now have to remove the crank pulley timing bolt and replace it. This gives me the opportunity to do something with that. I don't really want to spend £200 plus on a billet steel pulley.
I understand that with much higher RPM , uprated valve springs and potentially more aggressive cam profiles the loading on this interface is likely to be a lot greater than on an OE engine.
I am running OE cams with Rosten springs and plan on a fairly conservative RPM limit.
The ARP bolt for £50 seems a bit expensive if it only increases the load by 10% . I have seen that the 2.0 engines on newer cars seem to have a diamond coated washer to assist with this issue and this appears to increase the grip between the pulley face and crank end by upto 300% .
This is an OE VAG item at a reasonable price has anybody used one of these?.
https://www.akstuning.co.uk/engine-components/616-genuine-tfsi-crank-diamond-washer.html
Pinning the crank pulley seems an option but even that doesn't always work, and brings about the possibility of cracks in the pulley as the hole could possibly act as a stress raiser.
https://www.audi-sport.net/xf/threads/my-minor-modding-thread.76389/page-69#post-2225744
I bought myself a copy of the VW tool used to hold the sprocket, £25 delivered off fleabay and it seems to be just the right length too.
