So basically having no luck at all, brought a head as there was no compression on #2, but after the heads been removed, piston #2 is also knackered.
What block could I put in just to get the car running? And will it match up with the k04 bits?
Or would it be better to just change the one piston? However it's meant to be a bit scratched and marked around the piston? I just need a cost effective repair as its already cost me an arm and leg
