Hi Guys,
Yesterday me and my mrs went for a day out to the new forest. We ended up driving around 280 miles during the day. The car ran beautifully the entire time. After Leaving the new forest, we drove to Chichester to have dinner. On the way back driving down the a3 I noticed the car was lacking somewhat in power, it wouldn't rev higher than 2000 rpm even with my foot planted. I tried changing gear as I thought it might be blocked with carbon, and it threw a tone of black smoke out the back and was fine again. After driving up a bit of an incline the cars power dropped again. At the next services, I turned the car off and checked the engine bay for anything obscure. Nothing was found, so we carried on, as we drove down the a3 the car bogged down massively to a point I knew it was going to cut out. Eventually as I turned off the a3 to go onto the m25 it sure as hell did that. I tried to restart the car and was left in a plumbe of smoke. I tried to turn the engine over, it ran for a second and then killed itself. Sadly the car was then recovered close to my home as we can't get the car on the drive with the recovery truck.
Luckily for me, I've got VCDS. I've plugged it in this morning and got the following fault codes.
Initially I thought it was caused by a faulty turbo (could still be the case). I took the airbox off this morning, and removed the inlet hose, and I could not see oil in the turbo and there was no play. I took off the boost pipe going to the inlet manifold and I can the hose is lined in oil. I checked the oil this morning too and it looked okay, even though it is kinda parked on a slope right now.
Cars going to my brothers garage in the morning but wanted to get your guys opinions if anyones ever had this. I've only owned the car 2 weeks and done 800 miles. Its been running perfectly, I've only filled it up once and got 610 miles to the tank.
Code:
Sunday,24,February,2019,12:17:28:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WAUZZZ8E95A476683 License Plate: KW05HZC
Mileage: 212550km-132072mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E95A476683 Mileage: 212550km-132072miles
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 00551 210 84039
VCID: 75E157D51CC131E2F6-8020
7 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 128.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00101100
Temperature: 6.3°C
Bin. Bits: 00110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 128.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00101100
Temperature: 6.3°C
Bin. Bits: 00110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 128.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00101100
Temperature: 6.3°C
Bin. Bits: 00110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 128.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00101100
Temperature: 6.3°C
Bin. Bits: 00110000
16485 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Freeze Frame:
RPM: 1701 /min
Torque: 0.0 Nm
Speed: 85.0 km/h
Temperature: 18.9°C
Mass Flow: 17.07 g/s
(no units): 1.83
Temperature: 85.5°C
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
RPM: 2058 /min
Torque: 196.0 Nm
Speed: 103.0 km/h
Load: 100.0 %
Voltage: 14.36 V
Bin. Bits: 00101000
Absolute Pres.: 2325.6 mbar
Absolute Pres.: 1315.8 mbar
16787 - EGR Valve (N18)
P0403 - 000 - Malfunction
Freeze Frame:
RPM: 2604 /min
Torque: 132.0 Nm
Speed: 129.0 km/h
Duty Cycle: 76.5 %
Voltage: 14.14 V
Mass Air / Rev.: 885.0 mg/str
Duty Cycle: 45.0 %
Bin. Bits: 00000000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06325 000 00000
VCID: 2643409991E70A7A8F-8072
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AJ
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
VCID: 69D90BA51379E50262-515A
1 Fault Found:
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0304
Coding: 10001
Shop #: WSC 06325
VCID: 3B7581ED2965A792C0-4B18
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M0020PKZ
Coding: 0033622
VCID: 3B7581ED7A65A792C0-806E
Subsystem 1 - Serial number: 6332DRB400C2C9AC/
Subsystem 2 - Serial number: 6342DRB40EA3908F0
Subsystem 3 - Serial number: 6352ARB400436495D
Subsystem 4 - Serial number: 6362ARB4004354B3D
Subsystem 5 - Serial number: 63729RB40045A09FQ
Subsystem 6 - Serial number: 63829RB400459DB8Y
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04042
Shop #: WSC 06325
VCID: 4189F3054B89CD429A-4B32
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 950 S HW: 8E0 920 950 S
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0006441
Shop #: WSC 07713 067 57207
VCID: 39799BE573599582D2-513C
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006441
VCID: 39799BE573599582D2-515A
1 Fault Found:
01304 - Radio
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: 6BD571AD1985F71210-5178
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BM
Component: Komfortgerát T3B 2431
Coding: 07163
Shop #: WSC 06325
VCID: 7DF14FF577F169A2BE-4B18
Subsystem 1 - Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 B HW: 8E0 919 283 B
Component: Parkhilfe 4-Kan H06 0020
Revision: 00H06000 Serial number: 00067802030502
Coding: 0000014
Shop #: WSC 131071 1023 2097151
VCID: 2F6DA5BDBD1D4B327C-515A
2 Faults Found:
01543 - Parking Aid Warning Chime (H15)
009 - Open or Short to Ground
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 D HW: 8P0 862 335 D
Component: FSE_255x BT H18 0050
Revision: 00000001 Serial number: 00000000172149
Coding: 0001622
VCID: 377D9DDD454D83F224-515A
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 122
Time Indication: 15
End-------------------------(Elapsed Time: 06:58)--------------------------
Address 01: DTCs cleared
Address 03: DTCs clearedSunday,24,February,2019,12:27:30:00007
www.Ross-Tech.com
