2.0 TDI replaced Inlet Manifold adjuster not accepted by ECU
Surfnorway
Norway
Hi good afternoon,
Due to a broken intake manifold adjuster unit, I had the adjuster unit (VDO A2C59506246) be replaced for my audi allroad A4 B8 2010.
I know it is the right part as I checked the same OEM numbers required and bought the VDO (that was as well in my audi).
However, the ECU programming is giving now a code P201500 and is unable to define the right position.
The voltage is 5V continously and wiring is correct. I had it checked by the audi dealer.
The audi dealer states it could be that as it is not an original audi supplied part . But this VDO part it is exactly the same part as I changed.
Is there something I am missing in the learning - setting up of the part?
thanks!
Does vcds show a basic setting for its sensed positions.
thank for reply.
The audi dealer says it just gives error code , no position information.
Are you sure you fitted it right, was there a spring on there as swapped some out & also fitted some repair kits & they had a tiny spring.
You should be able to see the arm sensor readings in diagnostics when its moving.
Hi find attached the readings from VCDS
Saturday,13,March,2021,13:05:22:45471
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-NET2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WAUZZZ8KXAA082304 License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 62 69
72 77
VIN: WAUZZZ8KXAA082304 Mileage: 185500km-115264miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAGA) Labels:. 03L-906-019-CAG.clb
Part No SW: 03L 906 022 RJ HW: 03L 906 019 AL
Component: R4 2,0L EDC H21 8439
Revision: 25H21---
Coding: 32194012243603080000
Shop #: WSC 00040 218 18327
ASAM Dataset: EV_ECM20TDI03L906022RJ A02006
ROD: EV_ECM20TDI03L906019AL.rod
VCID: 7EAE9527607C6C0BFDF-802A
1 Fault Found:
5336 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 00 [101] - Implausible Signal
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 185490 km
Date: 2021.03.13
Time: 12:28:56
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 83 °C
Intake air temperature: 26 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 13.020 V
Unlearning counter according OBD: 40
Actual air mass: 0.0 mg/stroke
Intake manifold Runner Control (IMRC): activation: 100.00 %
Intake manifold Runner Control (IMRC): acknowledgment: 18.64 %
V Sw Vlv r Drft Clsd mp: 2.38 %
V Sw Vlv r Drft Opn mp: -8.98 %
V Sw Vlv st Mon-Bits 0-7: 0
V Sw Vlv st Mon-Bits 0-7: 55
V Sw Vlv st Mon-Bits 0-7: 6
V Sw Vlv u Raw: 0.0 mV
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K9 907 379 B HW: 8K9 907 379 B
Component: ESP8 quattro H07 0050
Revision: -------- Serial number: --------------
Coding: 048504
Shop #: WSC 06335 000 00000
VCID: 41D42EDB5182D3F3C0D-8014
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0326
Revision: 00002001
Coding: 032200
VCID: 0154EEDB110213F380D-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000061046014
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000081377009
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AH HW: 8T1 820 043 AH
Component: KLIMA 1 ZONE H08 0171
Revision: A1000000 Serial number: 01261020091913
Coding: 34200000
VCID: 77A080034FC65D43BE9-8022
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H28 0380
Revision: 10028001 Serial number: 00000000496301
Coding: 2600D0914034AF010001000300001D0D001C270804010101000000
VCID: 3C2A5F2F3660BE1B93B-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 251009 H06 0070
Serial number: SWF09100255105
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10655121
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000002210091374
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 H HW: 8K0 919 475
Component: PARKHILFE 4K H06 0050
Revision: 11001001 Serial number: 39940930205229
Coding: 110204
Shop #: WSC 06335 123 12345
VCID: 3E2E5527207CAC0BBDF-806A
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H39 0560
Serial number: 003EFD06UH8K
Coding: 30343435363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 41D42EDB5102D3F3C0D-8014
Crash sensor for side airbag: driver side:
Serial number: 6334MSME4A514476E
Front Passenger's Side Airbag Crash Sensor:
Serial number: 6344MSME4C52700EI
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 6352QSME62412D08D
Passenger side rear thorax airbag crash sensor:
Serial number: 6362QSME783F5610N
Crash sensor for front airbag: driver side:
Serial number: 63732SME5240080AS
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME1D40423A.
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 E HW: 8K0 953 568 E
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315IJF000C2
Coding: 000005
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 900 J HW: 8K0 920 900 J
Component: KOMBIINSTR. H20 0255
Revision: 00000000 Serial number: CIN31YUA9
Coding: 0F00290202000008010000
VCID: 31347E1BE122437330D-8064
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0105
Revision: GB600050 Serial number: 5000G09A1681C9
Coding: 00CF07
VCID: 50F21B9F8AE82A7B5F3-8004
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0125
Serial number: 00000000002790734803
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H14 0037
Serial number: 09282000594022001806
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00001010026084
Coding: 01581300000000000000
VCID: 3B285C33336EB9239A1-806E
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009545866
Coding: 011002205E00410001
VCID: 45DC3ACB45AAFFD3FC5-8010
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0123414240
Coding: 01000620203904C00120023680000000
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 F HW: 8R0 035 223 E
Component: DSP STD H11 0440
Revision: 00000000 Serial number: 00000000000001
Coding: 0103010101
VCID: 2F307863F7165583269-807A
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 112
Mileage: 185490 km
Time Indication: 0
Date: 2021.03.13
Time: 12:17:17
Freeze Frame:
Voltage: 12.10 V
Temperature: 17.0°C
Bin. Bits: 00000001
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009555335
VCID: 44DA27CF4E90C6DBEBB-8010
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000484139
Shop #: WSC 00000 000 00000
VCID: 343A770F1E30765B5BB-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 A
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 3822433F0E58923B773-806C
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
Component: Concert3 H04 0310
Revision: 00000007 Serial number: AUZ5Z6I1296119
Coding: 0502008201020100019B070000
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102198892
Coding: 010002204000210001
VCID: 42D621D75484C8EBD97-8016
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 B HW: 8K0 907 383 B
Component: Anhaenger H08 0080
Revision: 1A002002 Serial number: 00000123448527
Coding: 0100000000000000
VCID: 333874131B3E7163421-8066
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102198859
Address 77: Telephone Labels: RETROFIT77.lbl
Part No SW: KTC 364 31P HW: KTC 364 31P
Component: SWP:3.31.6 H24 0220
Revision: 00000000 Serial number: 00000000000000
Shop #: WSC 21977 142 74100
VCID: 33387413173E7163421-8066
End----------(Elapsed Time: 01:27, VBatt start/end: 12.2V/12.1V)-----------
I think if the sensor is part of the motor, then either the motors got a fault or wiring, installation issue, if there's a bank 1 sensor built into the actual manifold, then this is your next point to check as it maybe a manifold fault, I've known whole manifolds needing replaced due to the flap issue, whether it pertains to your engine, I couldn't say without reading up.
Did you have a sensor on the manifold itself, caga engine code?
If I get a chance I'll check documentation see if it has a sensor.
