The results from VCDS
Thursday,16,April,2015,15:45:07:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ8E17A037836 License Plate:
Mileage: 153300km-95256mi Repair Order:
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E17A037836 Mileage: 153300km/95256miles
Address 01: Engine Labels: 03G-906-016-BPW.clb
Part No SW: 03G 906 016 LQ HW: 03G 906 016 KP
Component: R4 2,0L EDC 200CG 1717
Revision: --H02--- Serial number:
Coding: 0000076
Shop #: WSC 66565 257 00032
VCID: 7DF11F7F2404B5F6FF5-8028
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E4 910 155 B HW: 01J 927 156 HT
Component: V30 01J 2.0l PD RdW 0010
Revision: 00000009 Serial number: 00000001044726
Coding: 0000001
Shop #: WSC 06335 000 00000
VCID: 285F1E2B9B06C05EFC3-807D
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004402
Shop #: WSC 06325 000 00000
VCID: 2C57E23B8FFEEC7E18B-8079
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0222
Hex Value: 0x0024
Hex Value: 0x017C
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
VCID: 6DD12F3F276425764F5-5072
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 10021
Shop #: WSC 06325
VCID: 3D71DF7F378475F6BF5-4A3A
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G25ZEH
Coding: 0030612
VCID: 3B75D1677A907BC6811-806E
Subsystem 1 - Serial number: 6332DRB403705328B
Subsystem 2 - Serial number: 6342DRB4035B941DU
Subsystem 3 - Serial number: 6352ARB4015B173FP
Subsystem 4 - Serial number: 6362ARB40165FB73V
Subsystem 5 - Serial number: 63729RB402826E26N
Subsystem 6 - Serial number: 63829RB4030A6356H
1 Fault Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksбulenmodul 0701
Coding: 04112
Shop #: WSC 06325
VCID: 4189A38F4B7C1116DBD-4A3A
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 P HW: 8E0 920 931 P
Component: KOMBI+WFS 4 H14 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0006011
Shop #: WSC 43265 134 173575
VCID: 3561C75F5FB4ADB6775-5072
2 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
01771 - Control Module for Headlight Range (J431)
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006011
VCID: 3561C75F5FB4ADB6775-5000
2 Faults Found:
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CD
Component: Komfortgerбt T01 4135
Coding: 23392
Shop #: WSC 06325
VCID: 75E1075F4F34EDB6B75-4A3A
Subsystem 1 - Part No: 8E1959801H
Component: Tхrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E1959802H
Component: Tхrsteuer.BF BRM 0606
Subsystem 3 - Part No: 8E0959801E
Component: Tхrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tхrsteuer.HR BRM 0606
2 Faults Found:
00955 - Key 1
35-10 - - - Intermittent
00956 - Key 2
35-00 - -
Address 77: Telephone Labels: None
VCID: 55A167DFBFF48DB6975-5072
End ---------------------------------------------------------------------
No fault codes in the engine.
There are two faults
00955 - Key 1
00956 - Key 2
35-00 - -
I cant understand this.
And this one too
Its from the imobilizer adress.
