2.0 tfsi cylinder head
Hi there quick question.does anyone no if the cylinder head from an s3 will fit an a4dtm
I can't see why it wouldn't, the only issue I know of is the S3 engine runs a lower compression ratio (happy to be corrected) I'm not sure if this would create any problems..
Thanks for the reply.from what iv read the dtm also has a lower compression ratio but they have different engine codes.also I think the inlet cam is meant to be slightly bigger
Apparently they also have forged pistons, but the rods aren't as strong as the S3.
From what I found out the other day, the engine internals are exactly the same as a golf gti, so no forged pistons. Someone checked on ETKA and the part number is the same. So nothing like the S3 performance wise (pistons and rods)
I have a head from a BUL that I've just a stripped if it's any use to you? Or it mite be a BYD which is the same never the less
