Hello my English isn't that good so yeah
Basically i have a problem with my a6 c5 , i went to get Diesel and before that everything was fine , after the gas station about 5km i wanted to overtake a truck put it in Tiptronic and switched from 5th to 3rd gear and it was rattling hard and got past the truck, then dropped to 4th and pressed the accelarator and rattling vibrating and lack of power ,so i got it pulled home with a rope only 10km , then i went on VCDS and only EGR opend code was there but its been there for 6months and run fine little laggy at low rpm but okay , so i checked the injectors and 3/6 cylinders were above 0.0 the others were -4,8 and -4,0 and i changed the filter but no change added additive to fuel still nothing , tested the injectors my self while getting the air out of , the fuel system all of 6 were pushing fuel through with force , so i was confused whats the problem i have some pics from VCDS from the injected quantity.
Help needed
Help needed
