Hi All, I'm hoping to secure an A6 Biturbo with the same engine as the S4. I'm intending to do the cambelt rollers tensioners, water pump, thermostat and relevant cam/ crankshaft oil seals etc and have been researching the procedure - i've done a few cambelts on the 1.9 engine so am familiar with dismantling the front of the car. I have access to the locking bar and crank pin and feel confident in stripping and replacing all the parts however its the tensioning that is causing me slight confusion. I understand the need to pop the cam pulleys off so that they rotate independently of the cams when tensioning but do you apply 15 NM's to the tensioner pulley and then pull the pin on the spring loaded tensioner or do you pull the pin and then apply the 15 NM's to the pulley. I cant find this info on the net anywhere.
Thanks in advance
Regards
Thanks in advance
Regards
