Anyone know of anywhere in the Swindon area that will be able to complete this?You'll need to find a good place to do the front alignment. It requires more adjustment than the bolts will give, it involves back off the subframe bolts as well - many places like National Tyres refuse to do it properly.
Just find a decent indi, I had mine adjusted after fitting sportlines at an indi, just standard 4 wheel alignment, (no special adjustments) I did about 40K miles on them with perfectly even wear onto my 2nd sets of P zero's
More pics please ... I have the same color, wheels combo
Get the chrome deleted! Check out my other posts for some picsThank you .... seems like a perfect drop
If you change the struts to Koni Special Actives, the crashiness goes and the handling is transformed to plush when pottering around to nice and planted when cornering.Hunter 4 wheel done, before and after.
The drop is great, car looks much more level as the rear looked higher than the front, ride is not much different on smooth roads, bit harsher on rough surfaces, avoid pot holes at all costs, much more crashy than standard, and a small amount of bounce over sharp drops like speed humps etc. using standard shocks. But I drive fairly sedately mostly so am not bothered. Not sure about getting 19s now though, think the two together will be too much without changing the shocks as well.
Got enough left in my pot for either a private plate (too much of a ponce?) or get the wheels powder coated black / painted black leaving the machined faces. Don't know which to pick yet..
