20” Rs3 wheels
45bvtc
The Older I Get The Better I Was
Supporter
Gold Supporter
You'd need the rim width to determine ET, seanick, and the tyre size too.
For sure I don't recall a 20" rim being reported anywhere as being successfully fitted on an 8P RS3 with STD wheel arches and for some even adding a 'wider' tyre and/or spacer to a 19" OE rim has caused fouling problems.
But try here for more information: https://www.willtheyfit.com/index.php?
And good luck...
tcardio
OEM RS3 20X 8.5J on 225/30/20 tires should do the trick. Adam Hodge did in on his S3 with widened front arches which may be the same width as the standard rs3 otherwise replacement arches available
Bazgti
Speak to Lisa from Awesome. 0161 776 0777. She has 20" and air ride on her S3 if i recall. As previous members have said. Standard arches had to go. She rolled the lips i believe.
