Hey all
Based in New Zealand, and a sucker for a TT. So a few months ago we found a slightly abused 1.8T Manual Quattro 225 for sale, listed as Pelican Blue and after purchasing and looking at the build sticker found it was Nogaro Blue! Originally imported from the UK, its not been a pretty car at the moment, massive overboost (N249 had failed), terrible tune on the car, clutch slipping etc etc.
So we set about fixing the general crappiness of the car and to use it as a daily whilst we decided what to do. Which lasted about 5 minutes, as I've bene personally dying to do a 1.8T build for a very long time.
Wheels in motion, the BAM engine is still in the car - sourced a lightly used AUM motor and stripped it down - its gone off to the machine shop for hot tanking, decking, honing and maybe an align hone/bore depending on what the ARP bolts change to the main caps. I am also trying to make sure I only build the motor once, and try to make it bullet proof
Currently the build is slated to be:
The head will end up:
Turbo choice is:
Gearbox:
Rest of the car so far:
My main concerns so far - is the G25-660 on the stock stroke and bore going to hinder my spool, and overall power band usability? I really want the car to react like the existing K04 in the car.
Do I use the locally made LinkTT drop in PNP ECU or the Ignitron ECU? Who here in NZ can support the tuning? Or am a looking at trying to remote link in to guys in the UK to assist whilst on a dyno?
Am I overlooking anything on this list, or should I be looking to do something else? BTW the short block is set in stone - so no chance to change bore or stroke now. Purchasing overseas parts in NZ is stupidly expensive and spare parts for early Audi/VW are almost impossible to come by.
- JE Forged Pistons - stock bore, stock CR (9.25:1)
- JE Tool Steel Wrist Pins
- IE Tuscan I Beam Rods - 144x20
- Calico main bearings
- Calico rod bearings
- ARP Main Stud Kit
- IE Billet Steel Crankshaft timing wheel
- ARP Crankshaft bolt
- 2.0TFSI Timing belt conversion
- 034Motorsport Rear Main Seal
- Fluidampr Crank Pulley
- All new bolts, gaskets, seals etc
- Small port head, ported to clean up the casting but will leave it small port
- ARP Head Stud kit
- IE intake manifold
- Grams Performance FBW Throttle body
- IE transitional phenolic spacer
- Supertech springs and retainers
- Supertech valves
- IE Street/Track Cams (new manufacturing run they did in April)
- IE adjustable cam gear
- Ekagrip Friction disc
- All new stems, valve guides
Turbo choice is:
- G25-660 .72 A/r External WG - Reverse rotation (annoyingly this was a stupidly good deal, but means I have to make my own manifold vs using a Nortech unit)
- Turbosmart 45mm WG (I can also use an Aeroflow, but I cant find many reviews on them)
Gearbox:
- 02M Manual 6 speed
- Wavetrace LSD
- Darkside Development shifter forks
- 600x300x76 FMIC fitted - 63mm piping
- All new Powerflex bushings all over the front
- Seat LCR Brembo brakes
- Its been lowered, but will likely replace this with some BC Gold coilovers
- Rear end requires refreshing
