RS4byfour
Hi, I need some help guys
My beloved RS4 has developed an engine noise.
It's like an alternator or tensioner bearing noise but it's internal.
I suspect it's coming from a worn bearing on the Gear Plate/ Gear Module inside the bottom of the engine (this drives all the pumps on the outside of the engine engine via shafts) or even the oil pump, ( apparently it has a gear driven counterbalance shaft inside it) which are all driven by the auxiliary chain.
I'm looking for a specialist on RS V8's to remove and strip it.
Can anyone suggest a trusted garage?
