2011 vw passat tdi multiple problems
romman
Hi i wonder if someone could give some help to a new user..from my log i seem to have quite a few faults which all occurred at the same time with three warning lights on the dash.
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 M HW: 3AA 614 109 M
Component: J104 C2 450M V4F3 0005
Revision: --H07--- Serial number: 000000xxxxxxx
Coding: 0002983
Shop #: WSC 05311 000 00000
VCID: 377DCD5746B85FA6659-8062
2 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 76
Reset counter: 28
Mileage: 55534 km
Time Indication: 0
Date: 2038.14.19
Time: 12:09:25
Freeze Frame:
Speed: 23.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 14.75 V
Bin. Bits: 00011111
Count: 12
Hex Value: 0x0000
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 76
Reset counter: 28
Mileage: 55534 km
Time Indication: 0
Date: 2038.14.19
Time: 12:09:25
Freeze Frame:
Speed: 23.0 km/h
Hex Value: 0x0000
Voltage: 14.75 V
Bin. Bits: 00011111
Count: 12
Hex Value: 0x0000
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: xxxxxxxxxxx
Coding: 010000
Shop #: WSC 05314 000 00000
VCID: 285F1E2B5B06C05EFC3-807D
1 Fault Found:
03138 - Input AUX IN
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 243
Mileage: 56039 km
Time Indication: 0
Date: 2039.14.15
Time: 18:00:28
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 194 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 3467FA5B57CEB4BE40B-8061
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 75
Reset counter: 28
Mileage: 56039 km
Time Indication: 0
Date: 2039.14.15
Time: 17:54:04
Freeze Frame:
Voltage: 14.88 V
DU
Temperature: 17.0°C
RPM: 774 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
Component: J540 EPB4 VW-55183 0007
Revision: H18 Serial number: 0000000xxxxxxxxxx
Coding: 0022067
VCID: 3365F94752C0B386591-8066
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 76
Reset counter: 27
Mileage: 55534 km
Time Indication: 0
Date: 2038.14.19
Time: 12:09:25
Freeze Frame:
Voltage: 14.80 V
Count: 106
Speed: 22.0 km/h
Hex Value: 0x1260
Hex Value: 0x0004
Hex Value: 0x0101
Many thanks in advance
