After keeping the spare key fob without use for years, I decided to test it to check if it would work in case I needed, but it didn't. It can't lock/unlock the car. Battery doesn't seem to be the issue because the LEDs in the key fob blink normally when buttons are pressed and, after all, the battery in the other key fob I use every day is still working perfectly. I tried the resync procedure from owner's manual (press lock, unlock driver's door using the key, press lock or unlock) but no success. Also tried pressing unlock while turning on the key in ignition but didn't work either. Any suggestions?
