hello i have charge only port but I want to upgrade it to data compatible port for car play I was able to find 8V0035708 part it is same as mine except it doesn't charge only can it be done?
Need correct part and wiring. The part you have linked is correct however its designed to be used with a font mounted USB also. You might be better with 81A035736.
