If you unplug valves and the car logs an error it will pull the power higher in the rev range, power graphs on this forum prove it.
Do you happen to have a link to the post / graphs showing this power loss?
Ok maybe I missed them. I'll read through the thread again.I believe they’re in this thread? Quite an obvious dip, mine had it also although you can’t tell when driving.
I was glad to hear about this. I had mine unplugged and while driving I didn't notice anything. The car doesn't exactly go into limp mode. But I'm hearing power is lost on the top end. Since the VW International plugs are out of stock, I ended up purchasing the simulator brackets from AWE. You remove the valves from the stock exhaust, keep them plugged in, and mount them to brackets that imitate the exhaust valves. That way, when the motors are plugged in but removed from the exhaust, they don't continually spin and burn out. All of this is due to me removing the exhaust for weight savings for an upcoming track day, FYI.
If anyone comes across the dyno graphs, I'd love to see them. Thank you!
Thanks for posting this graph. If I'm reading correctly, you made 421ft/lbs @ around 3600-3800 RPM, and then power started to drop. Is this the drop you are referring to? Are you saying with the plugs installed, you continued to make more power in that range, all else being equal?
Gotcha! That makes sense. Thanks for the clarification!
I see the dyno was on a 2017 RS3. I wonder if this affects 2018+ as well? I don't see why it wouldn't.
One last question ~ Does clearing the soft codes resolve this, at least in the short term?
@AudiNutta Will these plugs work on my PreFL Audi RS3?
Also whats motorway driving been like? is there alot of drone?
@AudiNutta my valve plugs got delivered today. When fitting, do you have to turn car on, put in dynamic and fit them while car on? Or select dynamic and then turn car off?
