Paul Richardson
- Joined
- Mar 1, 2017
- Messages
- 4
- Reaction score
- 2
- Points
- 3
Hi all.
I'm having a fuel problem with my 3.0 tdi Le Mans. It appears that there is no supply to the in tank fuel pump. The fuse is fine and I want to check the fuel pump relay but I can't find it!
All the information I have is its relay 614 and that it should be under the ecu in the electronic box in the plenum chamber. The box is dry but there is no 614 relay there, just 404 and 636. Checked the other electronic box in the plenum chamber and the relays behind the drivers bolster but still can't find it. Any advice folks?
Cheers.
Cheers.
