8v to 8p stalks retrofit
Poland
hello, has anyone tried to put on the stalks from the a3 8v to a3 8p? I care about the appearance of the 8v shifters. I started to redo them and managed to put them together. I have a problem with connecting the cables
Wysłane z mojego SM-G988B przy użyciu Tapatalka
Reactions: Mr_Dude
Did you check the signals are the same, as they may use a different protocol, let alone fitment.
Reactions: Sibmets
I managed to switch the stalks from 8v and they work 95%. The upper button that switches the options in dis does not work.
the other options work
Reactions: Mr_Dude and NHN
Nice job, shame about the dis button, can't you switch boards?
Did you cut & join the stalks parts to allow fitment into the 8P column?
Reactions: Mr_Dude and unilitePL
The base itself is from 8p, stalks from 8v, this item fits almost pług N play.
Left stalk and cruise control match 100% pnp.
But I still don't know why the fis option scroll up button doesn't work
very well, excellent upgrade!
it immediately gives the car another breath.
that can be put to work at 100%
Do you have any explanation on how to install? you could do a do it yourself
Enviado do meu iPhone usando o Tapatalk
Reactions: unilitePL
Different signal perhaps, assuming it still works up on the 8p stalks?
The stalk has a plate and three cables. The old stalk also had three cables. Plus, minus and control. I tried to plug it in so that it worked. Perhaps the microswitch is broken
Sorry for my English
It will be hard to explain. my English is poor. maybe someday I can make a movie
Reactions: Mr_Dude
my english is also bad :) but yes, making a video would help to understand and maybe more people make changes
I think it looked great in My car
Tbh I'd plug the 8p stalks back in to check they work, then see.
great steering wheel all buttons work?
Reactions: Mr_Dude
I assume some of your wheel buttons dont work or none work?
yes they are all working, with a module for it
send information where I can buy such a module
I can make a video and say which module I used
So what do the additional buttons do on the 8P, as in view, etc.
Reactions: Mr_Dude
the View button goes to the phonebook. the others do the same function as the original steering wheel
Yeah but you do have extra buttons more than the 8P usually has, what have they been programmed to do, thanks
Reactions: George Kost
Need this ;)
Oh wow, that's criminally expensive for a DIY mod. The board isn't even isolated with heatshrink and the wires aren't taped with fire retardant tape. Such a mod shouldn't cost more than 20 euro with the parts shown in the picture.
I have to disagree, for what it does, its a fair price.
Just because the parts maybe cheap, who pays for the time to build the unit, testing,the research & development.
Its really quite frustrating, when people just seem to think all these other elements are of no cost, time is money & the sellers time & effort has to be allowed for.
As for the build quality, it looks good, if it bothers anyone, takes seconds to put electrical tape around & the wires dont need fire retardant tape, the wire covering will already protect & if you have a fire in the steering wheel area, that module is your last concern tbh.
I truly believe it's a fair price for what he's selling, good for him.
Reactions: Mr_Dude
Check the resistors on the PCB. If many buttons are using a few wires, chances are there are a few resistors, with the module detecting which button was pressed based on the resistance. The button that isn't working probably has a different value resistor than the 8P one
Yes its works perfectly but in april i sold 8p
998
10
3K
14
6K
NHN
