A couple of things about 1.8t engine building
Djordje1
Active Member
London
Hey everyone
I'm working on a project car on the same platform as A3. 1.8t (new beetle 2000 AWV 150hp) and I'm building a new engine, completely
with new turbo g25-550.
I have a couple of things I'm concerned about and I would like to know your opinion. My goal is 450hp and these parts are related to durability and capabilities...
-Do I need a bigger MAF sensor? Which one do I need?
-Do I need a different Throttle Body? Which one do I need?I have this intake manifold https://fmic.eu/en/engine/168099-intake-manifold-fmic-pro-audi-vw-18t.html
-Do I need a custom camshaft bearing cap or I can use the OEM one? Which one do I need?
-Stock 2.0 TFSI main bolts or ARP?
Do I really need ARP bolts/studs or I can go with Elring main bolts for TFSI 2.0 as @desertstorm mentioned in one of the posts?"IStock 2.0 TFSI main bolts , these are upgraded over the stock 1.8T items and a lot cheaper than ARP . Stock Elring head bolts and Elring head gasket set."
-Head Bolts? Do I need ARP studs, bolts or there is also some cheaper and reliable replacements?
-Do I need new OEM (MAHLE) valve guides or I can use the old-current one? If not OEM which one do I need?
-Do I need a new OEM rocket arm or I can use old-current one? If not OEM which one do I need?
-Do I need a new OEM (AJUSA) valve stem seal or I can use an old-current one? If not OEM which one do I need?
-Do I need new OEM (AJUSA) valve lifters or I can use the old-current one? If not OEM which one do I need? (I'm changing camshaft, taking a new one...)
-Do I need a new OEM (MAHLE) inlet valve or I can use the old-current one, but just to polish them? If not OEM which one do I need?
-Which brand are you recommending for the gasket...? How does this one look like? https://www.bar-tek-tuning.com/1-8t-race-zylinderkopfdichtung-bar-tek?number=2118t88.5
Also, my plan is to reduce the temperature in the engine bay if possible.
-Where I can find a reliable embossed aluminum heat shield?
-Where I can find a reliable turbo blanket?
-Where I can find a reliable heat shielding sleeve?
-Where I can find a reliable Exhaust Heat Wrap?
There is a lot of questions I and will really appreciate if you have time to help me with any of these.
Thank you so much,
Hey everyone
Assuming you have a K03 based MAF already you would need at the very least the S3 MAF tube... the MAF sensor for a wideband K03/K04 turbo'd engine is the same, its the tube thats different...
Personally given your power goals you should bin the MAF and use a standalone like Ignitron and tune for speed density... a MAF at this power level and turbo is not the best thing in the world to tune and tends to lead to issues with low load/cruise situations...
You don't "need" a larger throttle body... the std 1.8t is perfectly capable... I couldn't tell you what is needed for that manifold specifically... not one I have used or seen before and nothing obvious in the description
Keep OEM, make sure they are the ones that came with the head and make sure you refit them back in the correct order as they are line bored for the head specifically
TFSI mains are 12.9 and I know Bill uses them on some builds (K04 hybrids etc) but on big power builds with larger frame turbos its ARP all day long...
ARP studs
Only ever used off the shelf guides... nothing specific... guide wear on a std 20v starts being noticeable on the exhausts from 50k miles on and there is no 'performance' guide that makes a difference... just use what ever you feel happy with
Rocket arm??
I have used Elring stem seals on pretty much every head I have ever built (a fair few) including my own on engines of 600hp +
OE followers are made by INA iirc... I have used parts supplied by our local motor factor, OE and sourced from eBay... they are all much the same as long as you buy from a trusted brand
OE inlets are generally fine... its the exhausts that need attention... bare minimum for a cammed high power spec is inconel exhausts, cat cam gold springs... you will need to use the triple groove exhausts when using the OE retainers
Depending on the piston size you plan then you only need to use an OE or Elring headgasket... these are suitable for bores up to 82.5mm... if you go 83mm then I have used IE modded gaskets which are just Elring ones honed out...
For a little extra peace of mind use some like Wellseal on the sealing faces
Thank you so much,
Any single or double layer alloy heat shield is generally fine
Turbo blankets tend to a bit hit and miss... not a massive fan of them personally and have seen cheaper ones catch fire
Plenty of heat shield sleeving on ebay... just don't buy too cheap
I normally use 'titanium' heat wrap... last lot I bought was less than 20 quid for 15mtrs and lasted the good 5 or 6 years the engine was in the car (longer than the IE 700hp rods at least... and no... I am not still bitter about it LOL)
<tuffty/>
Reactions: Jozua, MPH, hydro s3 and 1 other person
My thoughts - may differ from those more in the know than me but for what it's worth:
If you plan to keep the stock ECU, then it's worth going bigger. The nicer solution would be to drop in an Ignitron ECU and go MAFless.
Don't NEED, and can always be upgraded later
Nope
I've not looked into the TFSI bolts. Personally I'd drop ARP in for the cost, have seen OEM bolts snap with higher power.
Don't NEED, but not a bad thing to have if you plan to have the head off again in the future. Can always be added later. Caveat being if you plan to run high boost then maybe more worthwhile, but given your goal should be fine.
Replace exhausts at least, they're typically worn.
There aren't any rocker arms in the 1.8t.
Replace stem seals
If your lifters look worn or seized then replace those.
Inlet valves may be ok, though often replaced for peace of mind. Exhaust valves will need changing.
OEM/Elring is fine.
Heat is the killer, well worth adding protection :)
The likes of Nimbus sheet can be useful for the firewall and some components, the rest is no bad thing typically either. I've seen mixed reviews about turbo blankets but they do seem to be popping up more often.
The likes of Demon Tweeks and Funk Motorsport are worth a look, though there are plenty of other sellers offering the same/similar stuff so shop around a bit.
Edit: Tuffty replied while I was typing - take his advice over mine :laugh:
Reactions: <tuffty/>
Oh, thank you @<tuffty/> and @Rainbird for the quick reply. I very appreciate your opinion!
I'm sorry @Rainbird,but your comment is the last one :D However, you have pretty much the same thought.
I thought I need a new custom camshaft bearing cap because I'm changing camshaft and wanted to avoid micro-vibration, but I'll make sure they are in correct order.
Yes, I'm planning to use standalone ECU.
This is actually a rough list of the parts I'm planning to use in my build
Ultimate Road Spec Camshaft AUD20TBP285B
INTAKE MANIFOLD FMIC PRO AUDI VW 1.8T
VAG X-Beam Con-Rods 144 x 20 mm BAR-TEK®
ACL Motorsport Con-Rod Bearings
1.8T High-Performance Pistons-Kit WISECO" 82mm 8.5:1
1.8t Supertech Inconel Exhaust Valves
SUPERTECH VALVE SPRING SET
Nortech Performance Stainless Steel Tubular Exhaust Manifold V-BAND
Nortech Performance Downpipe
Turbosmart HyperGate 45m GenV black Wastegate
ARP CYLINDER HEAD BOLT KIT 204-3901
Luk dual-mass flywheel
Genuine Coilpack Adapters, 1.8t 20v, TFSI coilpacks (x 4)
Luk BR 0222
Sachs 4 Puk Clutch
Sachs Release Bearing
1000cc Bosch
Audi R8 Genuine Red Top Coilpacks NGK
Bosch 4-Bar Fuel Pressure Regulator
Garrett g25-550
ECU master black
Bosch waterPump
1.8T 20V VW & Audi Upgrade Fuel Pump 600 HP BAR-TEK
30 AMP Fuel Pump Wiring Kit
Gates Racing timing belt
Mechanical belt tensioner (kit)
High torque crank pulley (kit)
2.0 TFSI EA113 Diamond crank pulley washer
Bolt for crank sprocket ARP
Bolt for cam gear ARP
btw do I need catchcan oil?
What would be the maximum RPM I can use with this engine?
I forgot to ask about the fuel pump. I'm planning to buy this one? with wiring kit 30amp
What is your preference?
Did you combine dw65 and 44bosch?
Thanks,
Djordje
8.5:1 is quite low a CR... 9:1 or 9.25:1 would have been better...
82mm bore means you can use the standard headgasket so OE or Elring
Seeing as you have gone supertech for the exhaust and springs you may as well go for a full supertech setup and use the nitrited inlets... you will need the titanium retainers anyway for the exhaust double springs and I would suggest you go for the single groove over the triples
Use a 3bar FPR not 4bar
Catch can is a useful thing to have purely as it means you can clean up the PCV system
By 'high torque crank pulley kit' I assume you mean a billet crank wheel (belt not damper)... billet is fine
Personally would not rely on just an intank fuel pump... I run a Dw65 and 044 on mine
<tuffty/>
HEy @<tuffty/>
I already bought 8.5:1 pistons, but I really hope I will compensate for that with a new camshaft I hope so...Intake valves will stay more opened...But maybe is not enough to fill that gap between 8.5:1 and 9.5:1
1626784251068
Maybe I can go with a full KIT single groove also I have an option for +1mm size? Is it better to keep stock size?
Ok, that's means I have to use OE one 3bar???I remember I read somewhere on the forum that is 4bar recommended
The catch can is a useful thing to have purely as it means you can clean up the PCV system
My mechanic says if the engine is good you don't need oil catch can, but maybe I can install it just in case...
Yes exactly...
1626784904379
I think I'll follow your steps with an additional 044Bosch, btw are you using DW65 or DW65V, DW65C? Is it reliable? Also, know that AEM has a good fuel pump.
Did you upgrade the wiring and fusion for the fuel pump?
Cheers,
Thank you sooooo much,
Djordje
I also can share some additional work under the car :)
1626785585381
1626785601337
1626785607431
1626785612859
1626785618497
1626785635998
1626785651349
1626785738542
1626785754419
1626785767628
1626785773889
1626785778503
1626785789386
1626785808242
1626785817105
Reactions: Farmor00, S.Pellegrino, hydro s3 and 2 others
Firstly... I would suggest you have a read of my build thread.. its lengthy but has all this detail in... and lots of pictures :)
As you are only using a G25-550 I can't see why you would max out 1000cc injectors... I would start off with a 3bar FPR as this will give you better low pulsewidth performance on the injectors
Stick to std size vales... +1mm won't give you anything
Don't recall exactly what model DW65 I have but as I have an S3 its a quattro version... you would need the FWD version... as for reliability... this seems a grey area... generally they have been good... mines been fine over the couple or so years its been in... that said I know Bill has had a few failures over the years so anyones guess...
TBH if I was doing it again (which may happen) I would just fit an OE intank as all its really doing is acting as a lift pump for the 044...
<tuffty/>
@<tuffty/>
I'll definitely check, but I think I already read about your project. I'll check once again closely
Ok then I'll buy Supertech kit with stock size valves
1000cc I chose because most the people recommend even @desertstorm are using in his TT500hp build. What you're suggesting for g25-550? I'll go with 3bar then.
I have to check is there any difference between the new beetle fuel pump and S3, but I'll think about that to keep the OE pump and just add additional bosch 044 to push the fuel true the system.I understand what your talking about...Make sense
I just check the number, looks like I'll definitely need close to 1000cc what do you think guys?
1626794497128
Well... to add a little context then... I ran 1000cc injectors on a 2ltr stroker with a GT3582r producing 620hp at around 7.7k rpm... I had a 4bar fpr which gave me 80/90% IDC at 0.82-0.85 lambda on boost
1000cc at 3bar should be enough for 'pump' fuel on a G25-550 tbh but obviously if you the extra overhead then by all means fit a 4bar but it can affect fuelling at idle and cruise due to lack of linearity... a decent ECU will cope if its got a good wideband controller on it
<tuffty/>
<tuffty/>
@<tuffty/>
hey man!
Thank you so much for the info,I definitely don't want to do stuff just without purpose...I'll go with 3bar and 1000cc. Also, I'll go with dw65 and 044.
Did I want to ask about boost control and solenoids? How you're controlling your boost? Do you prefer a 2 port or 3 port solenoid? I have Turbosmart HyperGate 45m GenV black Wastegate and would be great to use full possibilities. There is also a lot of brands for solenoids? Which one is recommended?
Do I need any blow-off valve? Which one is the best? How strong spring do I need?
Thank you so much,
Djordje
If you haven't bought an ECU yet then buy an Ignitron... if you have already bought an ECU then sell it and buy an Ignitron...
Now that we have cleared that up... :)
.... I used the standard N75 on my 20v... I plan to use the N75 when I turbo the VR too... thats said... I know that Mac Valves work well as an alternative but I had no boost control issues with the OE valve so never felt compelled to change it...
Boost control is done through the Ignitron ECU... its proper PID closed loop control, multiple maps, WMI compensation and flex fuel capable... I have a load of examples of this in my build thread from when I was tuning Ignitron on my car..
as for a 'blow off' valve... they are essentially a 'safety' item designed to protect the turbo so fitting one is recommended... I used a Forge supersize diverter valve on the 20v and will reuse it again... spring wise I used a green so quite light as despite what the internet says its only actually a return spring as pressure should balance out in the valve top and bottom under boost so you shouldn't be using the spring to hold it shut...
If you plan to use a MAF then use a diverter (but nobody wants to use a MAF!!)... if you plan to use a proper ECU (Ignitron) and go speed density (recommended) then use whatever you want... just be aware that if you use an atmospheric valve and you plan to run WMI then place the valve before the nozzle else when you let off the throttle you will almost certainly expel meth mix as well as as charge air into the engine bay... which will be hot... and flammable stuff + hot = fire :)
<tuffty/>
Reactions: Djordje1
<tuffty/>
@<tuffty/>
Unfortunately, there is no way for me to go with ECU Ignitron, All parts I'm buying are mostly from the UK and that is no problem to buy ECU Ignitron. The reason is simple...I'm far away from the UK and that is the reason why I go with ECU master because the local tuner has a lot of experience with ECU master and that is the actually only reason why I decided to go with ECU master
I would love it that I have a chance to tune my car in the badger5 garage, but that is impossible...I have to drive 24 hours to do a dyno and tuning :D is too much :)))
I have to find some good blow-off that will fit on my intercooler pipe.
1626950537546
I'll definitely go without the MAF sensor we can use Map Sensor to read the data. I'll definitely stay far of WMI :)
Thank you so much for all this information. I'm so happy I have a chance to talk with people who already build 1.8t.
I really appreciate,
Djordje
Bill can remote map Ignitron if you need it and I tuned mine on the road as its that easy to do...
The ECU is nothing different from most others including ECU Master... if your tuner understands how to tune speed density then he is good to go...
In fact the VE table tunes itself!!... once you have done the base file using the base file wizard (Bill can also supply a base file if you require) then you literally just drive the car about to dial in the base VE table and go from there...
Ignition timing and boost maps are no different to tuning any other ECU so assuming your tuner is any good at all then tuning IECU shouldn't be an issue
If you are binning the MAF and going speed density then the MAP sensor will need to go in the plenum of the inlet manifold so it can see vacuum and boost (not in the charge pipe)
<tuffty/>
I'm going to blissfully ignore the rest of your post as Tuffty is doing a sterling job of answering with more experience than me, and instead I'm just going to make the point here:
Badger 5 offer remote tuning with an Ignitron. Save yourself two days' driving ;)
Oh, guys :) Maybe I worried too much, but this is my first build and I'm scared if something goes wrong we can't fix it remotely.
I need someone who is experienced and who can react at the right time in the right way. I actually thought about that and I contact Bill a couple of months ago and ask about remote tuning just because I know that Badger5 is based on Ignitron ECU I wanted that ECU! That is not the problem and to be the honest brand of ECU doesn't mean anything to me, please do not take me wrong. I choose ECU master just because I have experienced people around me, I would be more than happy if I'm living in the UK to bring the car to Bill's garage and enjoy and not worry about anything. Badger5 doing an amazing job and they are well known as one of the best for 1.8T engines.
I'll definitely share the results I believe there is always space to improve things. I'll be more than happy to hear your opinion. But before that I have to build engine first :)
Reactions: Rainbird
Fair enough dude... you have to do what you need to do... looking at the EMU Classic it appears on the face of it to have all the right comparable features with wideband lambda, knock sensors etc...
Looks like it supports VE based speed density tuning so happy days
Main reason for banging on about IECU so much is that its one of the best ECU's for the 1.8t on the market... its literally plug and play and of all the standalones I have ever used in the past its the first that essentially works out the box... in particular cold start which on most standalones is the biggest PITA job to sort out...
Anyhoo... happy to help a fellow 1.8t owner out even if its not an A3/S3... its the same platform at the end of the day and the same engine....
I have a 3.2 VR6 engine in my S3 and I am still hanging about on this forum while they let me :)
<tuffty/>
<tuffty/>
Thank you for understanding, unfortunately is like that. I did research and looks like a good ECU I'll go with the black instead classic version. More possibilities...
I can always change the ECU and map if something goes wrong and I'm not happy with the results I'll drive 24hours to do a different ECU and MAP :)
:D haha you know what I'm talking about. To be honest, is a very nice forum and it's the only one for 1.8t with an amazing comunity and people who want to help.
ooo 6 cylinders! I can't imagine the sound that the engine produces :)That is the proper engine :))
Thank you @<tuffty/>
You may want to look into the WMI. The positives outweigh the negatives. You could even just run a 100 percent blend of water if you're afraid of things catching fire.
WMI can seriously help lower IAT and EGT
Thank you @S.Pellegrino I'll definitely read about that. You never know :D
Hey everyone,
as your know my goal is 450bhp and I'm. wondering is this intercooler good enough...?
690x200x65
spec says excellent for 225bhp I also spoke with their sales...They said good for the 3bar.Ill run g25-500 on 1.8bar.
Do I need bigger one and which one?
I have to run that on new beetle.
Also I would like to by CSF radiator,but not sure which size I need and where in the UK I can buy it?
Thank you,
Djordje
Sent from my Mi A3 using Tapatalk
Hey everyone,
690x200x65
Thank you,
Djordje
I've heard a couple of sketchy things about Gravity Performance...
Hey everyone,
690x200x65
Thank you,
Djordje
That intercooler is waaaaay to small... do NOT base how good something is based on boost... boost is irrelevant in context...
I ordered my CSF radiator from here... https://csfrace.eu/ note that they are on back order and I have been waiting for 2 weeks so far for mine
<tuffty/>
Thank you @ that's the reason why ai asked this ...Because there is no sense for me how much boos can be in the system.
How ever ai see that the measurement per horsepower is CFM and I ask sales to provide more info how much air can be move true the system....
besidew that I'm thinking about some mishimoto universal intercooler.
Is there any intercooler you can recommend?I don't want to fail with incorrect parts.
Thank you everyone,
Djordje
Toyosport type B 600x300 is the goto FMIC.... just be careful as there are copies that used glued cores over brazed cores and don't perform very well at all
<tuffty/>
Thank you so much,I'll make sure that I'm buying right one this time...
Hey everyone, I hope you all doing well. I'm wondering where I can buy a reliable embossed heat shield for the firewall, turbo blanket, and Exhaust Heat Wrap in UK or EU? On eBay is hard to tell which one is good even if the price is higher, where did you find it?
Also, what is the general thought about heat wrap for exhaust manifold and downpipe? There are some rumors that that can cause cracking because of keeping the heat for longer than usual...
Btw if I go with R8 ignitions I need spacers, but do I need any other wires or different connectors?
Thank you,
Djordje
I wrapped my tubular mani on the 20v but haven't done that on the VR mani as its a cast mani and they are generally trickier with no real benefits in context..
I used this stuff for my downpipe though...
I have also used products from Funk Motorsport
Embossed stuff I just used what ever dual layered stuff was cheapest... its all about the same... its more how you use it (fnarr) than anything as its designed to take advantage of an air gap between it and the hot thing to work effectively....
Tubular mani's will crack regardless as they just do... cast mani's are subjective and depends on make/use/material etc
R8 coils are just TFSi coil packs iirc so taller than 1.8t ones... VAG do plastic adaptors that are cheap (I used these on my 20v)... there is info on TFSi coil packs in the stickies
<tuffty/>
<tuffty/>
this is very useful for me.I'll definitely do some warping.I'll start with downpipe and I'm thinking just to wrap until flexible part...
1637786049136
Looks like that is tubular manifold very tricky to wrap,btw this one looks really good.It's nortech... when you said "Tubular mani's will crack regardless as they just do... "
What is the timelife of the tubular manifold ?
1637786112893
There is also a question about the headgasket....I bought bartek kit with their Xbeam rods and wiesco pistons 82mm 8.5:1.They recomend https://www.bar-tek-tuning.com/18t-race-cylinder-head-gasket-bar-tek 1.68mm is there really any benefit compared with https://www.autodoc.de/elring/987525 1.22mm except obvious thickness difference. Most of the people on the forum use elring oe head gasket and I just wondering what is the best choice>? Also, I found a couple more different brands and thicknesses, but a bit cheaper.:
BGA gasket, cylinder head 1.35mm
AJUSA Dichtung, Zylinderkopf 1,35mm, MULTILAYER STEEL
ZZVF gasket, cylinder head/ Metal layer seal, 1.5mm
Is not a problem to buy the most expensive one, but if it's there any noticeable differences, no problem at all. What is your experience?
Thank you so much,
Djordje
<tuffty/>
I think I'll go with Funk Motorsport,they looks very good!
There is another option also, i had my downpipe done with ceramic coating.
I intend to have the same done to the turbo hotside and also the chinafold.
Dont want to steal this thread but i have a question about valvetrain.
I plan to supertech everything inside the cylinder head and want to renew as many things i can,would there be any negative effects when installing new INA hydraulic tappets on a head with cams that have done 250k km?
Does in not matter that the cam lobes have mated so to speak to the tappets?
So used cams but new tappets
Also i remember seeing somewhere was it Tuffty that mentioned about valve guides that no point in running "racing" guides.
What brand of valve guides should i use?
Only potential issue is that old cams tend to have pitting on the lobes that could potentially accelerate wear on the followers but this would be no different to keeping the existing followers in place....
There is no issues fitting new followers to old cams... they are not paired or anything like that... back in the olde days I used to use 'cam lube' when fitting cams and springs to engines and they always suggested running at 2000rpm on initial start for a length of time... this is more to ensure that oil gets up to the valve gear and prevent unwanted wear on the initial start of new parts... once 'bedded' in it was deemed fine
I would suggest that you should at least pour oil over the cams/followers before an first start and go for a fast idle to ensure that oil makes its up to the followers... or if poss use a bit of assembly lube...
No specific brand of valve guide tbh... I have only ever used whatever the head guy had in stock... its more important how they are fitted
<tuffty/>
No problem @LordSidious , thank you for the suggestion, I'll think it's easier for me to go with wrap, just have to think how to do it and on which part exactly...There is a lot of insulation blankets now. Literally for every part on the car :D
Guys, what do you think about gasket thickness and how important that is? I add some examples in the previous post.
Thank you
