a2 rear ciol springs
maxwan
hi , any one know how difficult it is to change the rear coil springs
cheers
Its not hard
Remove the wheel (use axle stands)
Pop the retaining clips on the inner arch lining
Undo the top 2 bolts and bolt one on the axle and remove
Undo the top bolt with a 23mm spanner (i think) and a small spanner to hold and support the piston from moving.
Make sure you use coil spring compressors
Simple answer, Yes its easy :sm4:
See pics here
http://www.audi-sport.net/vb/showthread.php?86172-A2-Suspension-upgrades
cheers
done with spring compressors very easy . no need to remove the wheel arch lining .
thanks
5K
6K
9
4K
