A3 2012 black edition electric fault
adamnodder
Hi,
I have a 2012 audi a3 black edition and ive started coming across a few issues which originally i thought i needed a new wing mirror indicator on the drivers side as it stopped working. Then the drivers door wouldnt lock, wing mirror wouldnt move when using the rotator inside the door and the window wouldn’t go up automatically with 1 click on the button id have to hold it down.
if anyone has any advice that would be great thanks.
NHN
Site Sponsor
Check door hinge rubber for broken wires.
adamnodder
Thanks for that, found a few wires which were broken. I found online a cable repair set which comes already assembled with the plug. Do you know if these are already connected up in the correct colour code or would i need to change it? Thanks
Matt268uk
A3 Sportback
You won't need that expensive plug, just but the same connectors and re join your broken wires. those connectors are really easy to use and are cheap. If you remove your door card and then your speaker you can pull the loom back through to give you the room to make repairs.
