josh trindade
I had some errors on 2 flap engines, mechanical errors, however today I disassembled everything, cleaned both, one of the engines was good and the other had to be replaced. I put everything back in place, the AC works better than before (it just blew cold air before), now it’s blowing hot and cold only.
The problem is i want to run the basic settings of the HVAC to realign the flaps, and nothing happens, the values all appear N/A N/A N/A N/A ... I click ON / OFF / NEXT button on the software the climatronic turns on and off, nothing happens...
In conclusion, after changing the flap, the only error that now appears is to run the basic alignment settings, which I cannot.
What should i do?
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 201
Mileage: 219706 km
Time Indication: 0
What should i do?
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 201
Mileage: 219706 km
Time Indication: 0
