wornclutch
Hi guys,
A complete noob here. I own an 8P A3 with BKD engine. First time ran a VCDS log with a friend's help. There are a few codes that came up in the scan. Engine runs fine but a few issues that I have with the car include,
- taking long to warm up/heater not working till the car warm up (possibly related to the Aux heater?),
- alarm going off intermittently while locking the car (unlocking and locking again seems to fix the issue),
- Dash lights auto dimming even when set to the highest setting regardless of the time (same thing happens during the day and night time)
I have searched the forum and ross tech website but still cant make sense of what are the main things I should be looking for. I understand that some codes could be caused by another fault so dont want to go on a spending spree to get something fixed that would have not be necessary at all. Below is the full log (module with no issues removed). If someone can have a look and help, it will be much appreciated.
Address 01: Engine Labels: None
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0200SG 5334
Revision: 12345678 Serial number: AUX7Z0C6FNT0EB
Coding: 0000072
Shop #: WSC 00066 001 57865
VCID: 270BFB81F3EEEAE3129-8072
1 Fault Found
19781 - Power Supply Terminal 15
P3325 - 000 - Implausible - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.07 V
Bin. Bits: 00000000
Bin. Bits: 0
(no units): 1.0
Readiness: 0 0 1 1 1
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 HW: 8P0 820 043
Component: KlimavollautomatH11 0130
Shop #: WSC 06435 000 00000
VCID: 698FBDB9257A1C93C4D-803C
5 Faults Found
00483 - Control Module for Auxiliary Air Heater
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Mileage: 279159 km
Time Indication: 0
Date: 2022.02.02
Time: 03:07:36
Freeze Frame:
ON
00797 - Sunlight Photo Sensor (G107)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 9
Mileage: 393216 km
Time Indication: 0
Date: 2032.00.00
Time: 00:00:00
Freeze Frame:
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 9
Mileage: 393216 km
Time Indication: 0
Date: 2032.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 14.00 V
(no units): 255.0
Temperature: -50.0°C
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 9
Mileage: 393216 km
Time Indication: 0
Date: 2032.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 14.00 V
(no units): 255.0
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 9
Mileage: 393216 km
Time Indication: 0
Date: 2032.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 14.00 V
(no units): 255.0
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103721A398
Coding: 3D0F0F42070101
VCID: 2615F685F4E4F3EB29F-8072
1 Fault Found
01304 - Radio
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 279159 km
Time Indication: 0
Date: 2022.02.02
Time: 03:23:40
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 188800186D288505485AC63000
VCID: 79AFEDF955DAAC1334D-802C
Subsystem 1 - Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H01 0010
1 Fault Found
01134 - Alarm Horn (H12)
000 - -
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
Revision: 00600000 Serial number:
Shop #: WSC 00000 000 00000
VCID: 2B0307B1EF06CE83F61-807E
1 Fault Found
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----(Elapsed Time: 01:08, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Coding: 0000072
1 Fault Found
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.07 V
Bin. Bits: 00000000
Bin. Bits: 0
(no units): 1.0
5 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Mileage: 279159 km
Time Indication: 0
Date: 2022.02.02
Time: 03:07:36
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 9
Mileage: 393216 km
Time Indication: 0
Date: 2032.00.00
Time: 00:00:00
Freeze Frame:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 9
Mileage: 393216 km
Time Indication: 0
Date: 2032.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 14.00 V
(no units): 255.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 9
Mileage: 393216 km
Time Indication: 0
Date: 2032.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 14.00 V
(no units): 255.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 9
Mileage: 393216 km
Time Indication: 0
Date: 2032.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 14.00 V
(no units): 255.0
1 Fault Found
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 279159 km
Time Indication: 0
Date: 2022.02.02
Time: 03:23:40
1 Fault Found
000 - -
1 Fault Found
014 - Defective
