monster_munch
My 53 plate A3 2.0 TDI has recently started having a problem with the passenger electric window, or rather the switch for it on the drivers side door.
I have done a search and seen e/w are a common problem, but mine doesnt seem to have the usual symptoms.
The passenger electric window operates fine from the passenger switch. However, on the driver side, funky things are happening.
When I 1/2 click the switch (to partially go down) nothing happens. When I fully click the switch (for it to automatically fully go down) it works and can then be stopped by selecting up.
However, when trying to raise the window, if I select fully up on the switch, the window only travels up an inch or so then stops, so I have to do this a few times to fully close it.
The drivers side window operates fine, and the passengers side window operates fine from the passenger switch.
I have tried to reset the switches (operating the windows then holding the switch down for a few seconds) but it makes no difference.
I have a 7 day road trip to France coming up soon, so keen to get the problem solved, but also dont want to take it to the dealers and get ripped off if I can get some initial diagnosis done myself.
Thanks in advance for the replies.
