Sounds about right. Ive crawled in the boot and tried to manually pop it with the little latch ain’t ****** moving. When I press the fob and the boot release, it makes a noise like it’s going to open then doesn't. Open. Then shows on the display that the boots open.This is the boot release their is a grommet in the boot liner you may have to climb in the boot through the back seats whith a torch
Thanks a lot. I will go red neck on it. See what happens. Thanks for the prompt responseForgot to say it won't open with emergency release or the key fob or button above number plate, its because the plastic screw and cog are worn out
