I am currently finishing my retrofit of Xenons from Halogen. I fitted the Kufatec harness & Xenons nearly 2 years ago, took one look at the . I have just retrofitted Headlamp washers, I found this quite simple really, on my car at least (2007 A4 Saloon). I have finally got my head around the level sensors, I have installed the extra cabling to both headlights, and fitted the front axle sensor, I'm gearing up to do the rear axle sensor next.
One thing I have learnt is that the Kufatec Harness needs to be adapted for RHD cars when it comes to can Hi / Lo and the fused power from S10. Could anyone tell me the closest can-bus link to behind the glove box? I have a CD changer in the glove box does this have can bus?
But my real question relates to the DRL. I plan on retrofitting the DRL switch not that my manual headlight adjustment is now defunct. I have the switch but it does not do anything when swapped over, i notice there are some differences in the pins between the 2 switches. Does anybody know what has to be done to get the DRL switch working?
