A4 B8 2.0 TDI - flashing glowplug and limp mode
Adill
Good evening,
A fellow member here kindly just scanned my car and was presented with the following codes. Can anyone shed some light please from experience
7 Faults Found:
5211 - Fuel Rail/System Pressure
P0087 00 [101] - Too Low
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 170972 km
Date: 2017.06.27
Time: 18:01:08
Engine speed: 3128.50 /min
Normed load value: 99.6 %
Vehicle speed: 47 km/h
Coolant temperature: 34 °C
Intake air temperature: 18 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.140 V
Unlearning counter according OBD: 80
Crankshaft speed (RPM): 3128.5 /min
Vehicle speed: 46.68 km/h
Mean injection quantity: 54.32 mg/stroke
Fuel temperature: 22.9 °C
Fuel high pressure: actual: 997400 hPa
Rail pressure regulation: status-Bit 0: 00000101
Inj Crv st Inj Char Act Val 0-Bit 0: 00111000
5213 - Fuel Rail/System Pressure
P0088 00 [101] - Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 170911 km
Date: 2017.06.26
Time: 18:40:33
Engine speed: 1361.00 /min
Normed load value: 55.3 %
Vehicle speed: 57 km/h
Coolant temperature: 82 °C
Intake air temperature: 25 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.020 V
Unlearning counter according OBD: 79
Crankshaft speed (RPM): 1361.0 /min
Vehicle speed: 57.95 km/h
Mean injection quantity: 20.04 mg/stroke
Fuel temperature: 39.6 °C
Fuel high pressure: actual: 1.4594e+006 hPa
Inj Crv st Inj Char Act Val 0-Bit 0: 00011000
5456 - Starter Will Not Turn
P3054 00 [096] - Jammed or Electrical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
5253 - Diesel Particle Filter; Differential Pressure Sensor
P2452 00 [175] - Elect. Malfunction
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 165949 km
Date: 2017.03.17
Time: 09:36:55
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 47 °C
Intake air temperature: 23 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.660 V
Unlearning counter according OBD: 40
Crankshaft speed (RPM): 0.0 /min
Vehicle speed: 0.00 km/h
Vehicle voltage terminal 30: 13660 mV
Particle filter: difference pressure: 0 hPa
Particle filter: offset for differential press.: 47 hPa
Exhaust gas vol.flow particulate filter: 0.0 m³/h
Intake air temperature: 23.2 °C
4985 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [096] - Electrical Fault
4986 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [109] - Electrical Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 165949 km
Date: 2017.03.17
Time: 15:22:39
Engine speed: 880.50 /min
Normed load value: 38.4 %
Coolant temperature: 12 °C
Intake air temperature: 9 °C
Voltage terminal 30: 11.200 V
Crankshaft speed (RPM): 880.5 /min
Vehicle voltage terminal 30: 11200 mV
Coolant temperature: 12.9 °C
Glow status-Bit 0: 00000000
Glow status-Bit 8: 00000000
Preheat time: 1600 ms
Fuel temperature: 10.5 °C
5174 - Fuel Pressure Regulation
P1065 00 [109] - Regulation Discrepancy
Freeze Frame:
Fault Priority: 2
Fault Frequency: 25
Mileage: 170908 km
Date: 2017.06.16
Time: 13:22:04
Engine speed: 1820.00 /min
Normed load value: 59.2 %
Coolant temperature: 17 °C
Intake air temperature: 20 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 12.580 V
Crankshaft speed (RPM): 1820.0 /min
Vehicle voltage terminal 30: 12580 mV
Fuel high pressure: actual: 970600 hPa
Mean injection quantity: 20.12 mg/stroke
Fuel Metering Valve: 21.83 %
Fuel Pressure Regulator Valve: 21.93 %
Readiness: 1 1 0 0 0
Check your fuel filter first.
Thank you. I've changed the DPF sensor but coming back with the same fault. Will change the glow plugs / fuel filter and then try the high pressure fuel pump. I also bought a genuine Vcds cable so will scan and report. Does anyone know of a guide of how I can enable the extra features such as dipping the mirror when selecting reverse etc
DPF sensor error has gone. Now just to trouble shoot the fuel pressure codes
changing the fuel filter hasn't helped with this
