A4 Cabriolet Roof Adjustment
longmanjon
hi, the wifes a4 cab has a leak on one side, i have checked the seals and they look fine. i have poured water down the drain holes and the water comes out so i assume these are working but may try pushing some wire in there to be sure.
i have read that you can adjust the roof so that it clamps more, does anyone know how this is done?
When the roof is down are the front windows the same height?
Ours is leaking on the passenger side and you can see that window doesnt sit as high into the roof sealas the other one.
Yes both windows seem to be at the same height. I have clean the drain holes and there didn't seem to be any noticeable muck coming out. I shall wait and see then try the adjustment. Thanks for the link
