Hi
I'm new to this forum and seeking some advice please. I have a 02 2.6 a4 cabriolet and the problems I'm having are:-
Roof will not go down. I've tried resetting this by opening and closing manually but this does not cure the problem. When I press the open switch the windows go half way down then stops, however if I open the roof manually and slightly push the roof up away from the frame and press the switch the roof will go down as it should, but then stays open until I close manually.
The central locking will not operate correctly if I press open/ close this will only open the passenger door and boot. I have to manually open the drivers side with the key. I've tried resetting using both keys, one in the ignition and the other in the door but this fails. The internal locking switch only clicks when pressed and does not lock or open.
This weekend I opened the car with the key and the passenger rear window went down and stays down. I've tried to close the window by turning the key ant clockwise but nothing happens.
The car was serviced last October and no fault codes were flagged up.
All was working fine when I purchased the car. The last time the roof and central locking worked fine was last summer. The roof was down when the sky decided to open with a quick downpour. Since then I've had these problems.
Any advice appreciated, is this a garage job? Sorry for the long message but I'm at a loss.
