Darryn
Hi Chaps,
Got a A5 with a few faults onboard and wondered if anyone out there could offer some additional insight for me to further diagnose these issues.
1) In the engine fault list I have a power bus train fault appears to be a coding issue but my version of VCDS does not show the long codes.
2) Headlight range fault but both sensors are working and throwing out height values in the measuring blocks and voltages are fine.
3)Camshaft adjustment 1 fault.
4) pulling off from standstill there is a slight jolt but only occasionally.
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56
Mileage: 245940km-152820miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine (J623-CGKA) Labels:| 059-907-401-V1.clb
Part No SW: 8K1 907 401 A HW: 8K1 907 401 A
Component: 2.7TDI EDC17 X01 0008
Revision: 15X01---
Coding: 0114002C02070120
Shop #: WSC 26214 051 00000
ASAM Dataset: EV_ECM27TDI0118K1907401A 001012
ROD: EV_ECM27TDI0118K1907401A.rod
VCID: 2A5A3A344DFF2816EF-807E
1 Fault Found:
4332 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 245948 km
Date: 2019.05.17
Time: 14:11:59
Engine speed: 639.00 /min
Normed load value: 27.5 %
Vehicle speed: 0 km/h
Coolant temperature: 46 °C
Intake air temperature: 25 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.080 V
Unlearning counter according OBD: 40
Crankshaft speed (RPM): 639.0 /min
Vehicle speed: 0.00 km/h
Acceleration: 0.000 m/s²
ACCI a Des: 0.000 m/s²
ACCI st State-Bit 0: 00000011
Cruise Control System (CCS): status-Bit 0: 00000100
ACCI st Brk Err mp-Bit 0: 00000000
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
Component: ESP8 front H04 0060
Coding: 1A0500
Shop #: WSC 06325 000 00000
VCID: 78FED07CCBD34A86A9-802C
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 13:59:28
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 S HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0140
Revision: D0000000 Serial number: 0102.08.080558
Coding: 36060000
VCID: 428A7294DD8FD056C7-8016
1 Fault Found:
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 13:59:48
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H22 0253
Revision: 04022001 Serial number: 00000000193244
Coding: 260050914034AF010009000000005D5D001D438800010141000000
VCID: 2F6C2B207E1D4D3E38-807A
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 239
Mileage: 245932 km
Time Indication: 0
Date: 2019.05.17
Time: 07:55:00
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 D HW: 8K0 919 475
Component: PARKHILFE 4K H06 0020
Revision: 11001001 Serial number: 52930821206728
Coding: 000101
VCID: 3A7A0A74B55F98969F-806E
1 Fault Found:
02070 - Rear Parking Aid Sensors
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 14:14:06
Freeze Frame:
Temperature: 0.0°C
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 B HW: 8T0 920 981 B
Component: KOMBIINSTR. H30 0224
Revision: 00000000 Serial number: 9D654GC88
Coding: 2F07000002002600010000
VCID: 3B740F70BA65A19E84-806E
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 14:00:4
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H70 0134
Revision: 00002001 Serial number: 0112918991
Coding: 011B068200390400002000
VCID: 306E285C632352C621-8064
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 14:01:15
01120 - Camshaft Adjustment 1
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 14:01:13
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000001
Shop #: WSC 06324 000 00000
VCID: 3466244C573B6EE645-8060
2 Faults Found:
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 14:06:57
01536 - Vehicle being Lowered
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 7
Fault Frequency: 1
Reset counter: 239
Mileage: 245949 km
Time Indication: 0
Date: 2019.05.17
Time: 14:21:10
Revision: 15X01---
1 Fault Found:
P1647 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 245948 km
Date: 2019.05.17
Time: 14:11:59
Coding: 1A0500
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 13:59:28
Coding: 36060000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 13:59:48
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 239
Mileage: 245932 km
Time Indication: 0
Date: 2019.05.17
Time: 07:55:00
Coding: 000101
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 14:14:06
Freeze Frame:
Temperature: 0.0°C
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 14:00:4
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 14:01:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 14:01:13
Coding: 0000001
2 Faults Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 239
Mileage: 245948 km
Time Indication: 0
Date: 2019.05.17
Time: 14:06:57
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 239
Mileage: 245949 km
Time Indication: 0
Date: 2019.05.17
Time: 14:21:10
