Tez_14_2000
- Joined
- Aug 6, 2015
- Messages
- 14
- Reaction score
- 14
- Points
- 3
Hey guys.
I'm pretty new here and haven't had any time to post much, but when I first had this problem I asked on here and everywhere else and couldn't find a sensible answer to the cure... I was sad one person even say they just turned their stereo up?!?
In any case, this was the problem...
A month or so after I bought my a5 (2008 model with 60,000 miles), I had jst left the house when there was a loud popping or sort of plastic banging came from my dash. It would bang over second or so for 12-25 seconds at first... Then stop for a bit... Then come back.. But for different periods of time. I could tell it was the heat box, near the top of where you'd expect the matrix to be.... Best discribed as behind the left side of the nav screen, below the left side of the windscreen vent...
Eventually it stopped and I heard no more from it for months, until the autumn.... When it came back with a vengeance. It was almost non stop, and irritated me so much I parked the car up and wouldn't drive it.
I done some digging online and spoke to some audi mechanics etc and Noone could give me a definitive answer as to what it was, Noone had fixed it before. I found this odd because there seemed to be a handful of others online complaining of the same thing.
In general tho the concensus was the same, a heater motor for the climate control that was either on its way out or broken.
I'm in car body work and am fairly handy at most things but stripping a dash on an audi didn't sound like fun, I had done a couple of Hondas etc and even they were a nightmare and very time consuming.
In any case I couldn't find anyone who was willing to do it that I would let work on my car (especially interior, if not done right your left with squeaks Abd rattles all kver the place) so I decided that over Christmas I'd have a go myself at pulling the dash out in the hope to get some answers.
So about 6 hours later, I had the car stripped and could see the various motors that work the climate control.
Turned out it wasn't a motor, but there was a plastic mount which held the passanger side blend motor (temp control) into place which also clips over the gear on the heater box which moves the flap. This had broken and so the gears were slipping over one another, and with ever tooth that slipped, obviously I would get this banging sort of sound.
I rang audi and they stocked the part (again pointing to the fact that they must sell them on a regular basis, thus this I presume if a common problem).
When it arrived I used a 2k apoxy glue we use in work to reinforce the bit that broke on the old motor holder and built the car back up again... Another 4.5 hours later..Job done! Problem fixed.
And this is where you guys can really benefit if u have the same problem...
With the dash stripped out I could see how the motor was held in etc and it's actually on a slide, and the only screws holding it are to one side of the heater box.
Also, the main heater motor and it's housing which is behind the glovebox is actually held into place by a single sliding clip on top of the assembly.
So once I knew the car was fixed I tried removing the motor again with this new knowledge...to confirm the theory that there's an easy way of doing this...
Remove the govebox, remove the left kick panel from the foot well, remove the two heating ducts infront of the heater motor housing, reach up the top where this joins the main heater box and there's a white plastic slide which u lift and pull.. The heater box falls away at the top and lifts out of two locators at the bottom, once that's gone, there are two screws which are tricky to get at but accessible... The motor holder simply slides out with the motor inside it!!!
Locking the motor housing into its slide and correctly getting the gears interested and everything right can be a little tricky from here but it's doable when u know what's going on at the top (which u can't see with the dash in place obviously)... But all in all it makes this a 40-45 minute job when u know what ur doing!!!
So I hope that there's someone who can benefit from this, I'm sure it's a problem others have had.
If nothing else, the images are interesting to see what's in there.
Cheers,
Terry.
Here u can see the white motor holders location ontop of the hear box, roughly where I thought the banging was coming from:
The broken holder, no longer holding the gears together properly :
U can see the missing bit of plastic toward the bottom of the photo on the old holder on the right in comparison to the new holder on the left:
Cheers,
Terry.
