A8 mmi issue..
Nokesy
Hi Guys (and gals!)
Got an A8 with a bus problem where the whole infotainment network is down, done some reads of the car and on the forums, told to chance the controller mmi panel, which I did, but hasn’t fixed it. I have noticed that the fuse for the phone keeps blowing even when the module is disconnected and I run an optical bus check.
Can I
A: put an optical loop in so I can get the network running and then code the phone off
Or
B: get one of you wiz’s to help me fix it…
Reads are as follows:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 72 76 77
VIN: WAUZZZ4E83N004745 Mileage: 168670km-104806miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: Cannot be reached 1100
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
57-TV Tuner -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 HW: 4E0 907 560
Component: 4.2L V8/5V G 0060
Revision: 00000000 Serial number: AUX3Z0BD106209
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 5EB8E5AC89BA47D13C3-800B
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 HW: 09E 927 156
Component: AG6 09E 4,2L5V RdW 0060
Coding: 0000001
Shop #: WSC 02312 785 00200
VCID: 5FC6D8A88EB04ED9375-800A
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0400
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 21429E50F8443829411-8074
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H01 0070
Revision: 00703201 Serial number: AUX3Z0BD106209
Coding: 0264192
Shop #: WSC 02311 785 00200
VCID: 58B4F3B4EB9EB9E176F-800D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 B HW: 4E0 959 760
Component: Sitzmemory BFS H05 0020
Revision: 00000000 Serial number: 5DS 008 795-02
Coding: 3670016
VCID: 2240915CFD42233158B-8077
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 011 0190
Revision: 00000009 Serial number: 00000000007669
Coding: 0020545
VCID: 5AB0E9BC9592ABF140B-800F
6 Faults Found:
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 2
Reset counter: 243
Mileage: 204260 km
Time Indication: 0
Date: 2012.03.12
Time: 15:11:22
Freeze Frame:
Temperature: 20.0°C
00739 - Coolant Circulation Pump (V50)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 254
Reset counter: 28
Mileage: 204260 km
Time Indication: 0
Date: 2012.03.12
Time: 15:11:22
Freeze Frame:
Temperature: 95.0°C
01857 - Air Outlet Sensor; Middle Left (G347)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 28
Reset counter: 18
Mileage: 268556 km
Time Indication: 0
Date: 2002.11.11
Time: 19:50:07
01851 - Position Sensor; Defrost/Upper Body Shut-Off Flap Motor; Front Right (G317)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 13
Mileage: 271024 km
Time Indication: 0
Date: 2002.12.05
Time: 22:27:12
Freeze Frame:
Voltage: 13.50 V
(no units): 149.0
(no units): 255.0
01273 - Fresh Air Blower (V2)
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 14
Mileage: 271094 km
Time Indication: 0
Date: 2002.12.12
Time: 00:30:20
Freeze Frame:
Temperature: 19.0°C
Speed: 8.0 km/h
(no units): 68.0
(no units): 169.0
01858 - Air Outlet Sensor; Right Center (G348)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 171
Reset counter: 28
Mileage: 267182 km
Time Indication: 0
Date: 2002.10.24
Time: 20:42:19
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 A HW: 4E0 907 279 A
Component: ILM Fahrer H11 0070
Coding: 0010001
Shop #: WSC 00000 000 00000
VCID: 26488D4C916ADF11343-8073
Subsystem 1 - Part No: 4E2 910 113
Component: Wischer WWS D3 H30 0310
Coding: 00000033
Shop #: WSC 00000
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H08 0840
Coding: 0431707
VCID: 63CED458A2D86A3913D-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H08 0020
Coding: 0112141
VCID: 65CACA40ACEC1409FD9-8030
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 C
Component: KOMBIINSTR. VDO H38 0020
Serial number: AUDID3BD000025
Coding: 0000403
Shop #: WSC 02629 067 57207
VCID: 5CBCEFA49FA655C1527-8009
1 Fault Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 00000011
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Mileage: 265244 km
Time Indication: 0
Date: 2002.09.13
Time: 00:16:23
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H06 0040
Revision: 06 Serial number: 0000302B26142D
Coding: FCFE7BDC2B3504
Shop #: WSC 00000 128 00289
Address 1E: Media Player 2
Cannot be reached
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0264192
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 C HW: 4E0 907 553 C
Component: LUFTFDR.-CDC H03 4190
Coding: 0015500
Shop #: WSC 00613 210 69644
VCID: 234E9458E2582A3953D-8076
1 Fault Found:
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 243
Mileage: 271458 km
Time Indication: 0
Date: 2002.12.24
Time: 23:19:46
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H05 0020
Coding: 3670018
Address 37: Navigation
Cannot be reached
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0060
Serial number: 00000232300127
Coding: 0035856
VCID: 1D3AA2A0C43C1CC9659-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: Türsteuer.FS BRM004 0060
Coding: 0026914
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 HW: 4E0 907 289
Component: Komfortgeraet H02 0050
Coding: 0000729
VCID: 66C8CD4C51EA1F11F43-8033
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H01 0020
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Reset counter: 243
Mileage: 139907 km
Time Indication: 0
Date: 2009.07.22
Time: 11:35:43
Freeze Frame:
Raw, Form. N/A: 000 000 000
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H06 0050
Revision: Serial number: 00000000006817
Coding: 0010101
VCID: 5DBAE2A084BC5CC9259-8008
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: Türsteuer.BF BRM004 0060
Coding: 0026914
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000531
Shop #: WSC 02629 210 01865
2 Faults Found:
02596 - Rear Brake Pads Worn
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 15
Reset counter: 240
Mileage: 271432 km
Time Indication: 0
Date: 2002.12.23
Time: 00:42:22
Freeze Frame:
Voltage: 12.01 V
Count: 60
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 240
Mileage: 271216 km
Time Indication: 0
Date: 2002.12.18
Time: 00:08:03
Freeze Frame:
Voltage: 13.77 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: AFS 1.Stufe H01 0020
Revision: 00000001 Serial number:
Coding: 0000001
VCID: 62C0D15CBDC2633118B-8037
Address 56: Radio
Cannot be reached
Address 57: TV Tuner
Cannot be reached
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000006431
VCID: 20449B54F34E31214EF-8075
Subsystem 1 - Part No: 4E0 915 105
Component: von VA0 4047023479
Coding: 344530393135313035202056413034303437303233343739
Shop #: WSC 00011 888 06946
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0060
Coding: 0026914
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0060
Coding: 0026914
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001008
VCID: 60C4DB54B3CE71210EF-8035
Address 77: Telephone
Cannot be reached
And optical bus network read:
Control Module Part Number: 4E0 910 468
Component and/or Version: Gateway H06 0040
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK OK
07-Control Head(High/D3) OK OK
1E-Media Player 2 OK OK
77-Telephone ERROR ERROR
47-Sound System OK ERROR
56-Radio OK OK
57-TV Tuner OK OK
37-Navigation OK OK
Cheers!!
cocain
RAA RAA like a dungeon dragon!
I'm not a whizz but I would use the optical loop down by the phone bluetooth module under the passenger carpet. You may have a damged cable somewhere.
Nokesy
So, your saying that the A8, not only has the module under the arm rest, which has the audi phone in it, but also has a bluetooth module under the passenger carpet? is this front or rear? do you know where I can buy a optical loop bypass from if this is the case?
cocain
Sorry for the late reply as i've not been on for a while.
I'm not sure about the phone module under the arm rest. I have taken my phone cradle out as it is pointless if you have bluetooth and I'm not sure if there is a seperate module there. My phone and bluetooth was working fine then I disconected the phone just to use blutooth all good for 6 months or so. It stopped working (errormessage phone not connected) so I bought a bluetooth module. i took out the old one without replacing the new one right away and it stopped the mmi from working because it brokle the optical ring network. Plugged the broken blutooth module back in and MMI worked again. So I would buy the bypass loop (ebay they're not expensive) and place it on various places on the optical ring where modules are to see which one it is. If there is one under the arm rest I would start there then the blutooth one under the carpet.
Also have you tried posting in Audiworld.com? the a8 forum is a little busier than here
