Coming home from work Sunday morning and my abs light came on, and suddenly a grinding/scraping noise from the passenger side brakes. Pulled over and my pads are both touching the disc at the bottom. So they're angled if you get what I mean.
Had to get home which was 60mile. anyway it drives fine but I can't get the pads to come level, or even off the disc. The noise gets worse when I turn left or right, and is bearly noticeable when going straight. To make things even better I'm that flat out with work I don't even have the time to get the wheel off and strip the calliper down. So might be a garage job. But I'd rather know what it's going it for before hand.
Scanned when I got home;
Fault code 00283 - ABS Wheel Speed Sensor Front Left (G47): Mechanical Malfunction
Possible Causes
Excessive Air Gap between ABS Wheel Speed Sensor Front Left (G47) and pick-up.
Depending on the equipment this could be on the Rotor or Bolt-on wheel bearing assembly
Damaged, incorrect or rusted pick-up ring
Short Circuit in Wiring from/to ABS Wheel Speed Sensor Front Left (G47)
ABS Wheel Speed Sensor Front Left (G47) faulty
Possible Solutions
Check ABS Wheel Speed Sensor Front Left (G47) Installation
Check the pick-up ring
Check Wiring from/to ABS Wheel Speed Sensor Front Left (G47)
I'm thinking the piston isn't going back?
Any help or advise would be great.
Ive got tyres and top mounts ready to fit, and I've ordered a new sensor for piece of mind. Will try and upload a video as well.
Possible Causes
Possible Solutions
