Hi guys, so as the title states I've been having an issue with my ABS. At slow speeds the abs kicks in, can feel it in the pedal and can hear the sound of the pump. It doesn't flash the abs symbol on the dash however which is odd
I had the cars brakes bled last week and its still doing it, I suggested doing the bleed on vcds as ive seen a lot of people on here suggest but the guy used quite a large pressure bleeder. Admittedly there was quite some air in the lines and even a blockage on my LF, I have 18z front brakes and with them having the 2 bleed niples at top the inner one when opened didnt let any fluid out. I had to press down hard on the brake pedal along with the pressure bleeder going and whatever it was it blew out, also had some dirty dark fluid come out the LR
Now my question is, has anyone came across this before? Is there a way to bleed the MC and ABS pump themselves incase there's any air there or would any air of been forced out with the pressure bleeder
Apologies for the very long post but hoping someone may be able to help
Josh
Josh
