Hello,
I posted before about an ABS issue - ended up changing the sensor, hub and even the wiring loom through the inner wing (still doesn't work)
So I'm after the pinouts of the abs module connector OR the wiring diagram if it tells you which pin the sensors go back to on the module connector
The Haynes manual came in handy for second fuel tank level sensor and instrument cluster connector but for whatever reason the ABS wiring has been left out and I don't have elsawin!
The fault code that came up was 00290 - ABS Wheel Speed Sensor Rear Left (G46): Electrical Fault in Circuit
...and yes I have that magical badge of genuine VCDS as that seems to be a requirement for help in some cases
Thanks in advance
Alex
Thanks in advance
Alex
