ACC sensor fault - moved
random101
Hey all,
long story short - new IC sensor is moved and now ACC won’t work.
Is there a way to readjust it and reset it at home via VCDS?
I went into the Vcds cleared codes ect- but then I went into module 13 and tried to reset the 4 options in there.
Though I ended up getting this yellow light -
which is a distance fault.
I never had this fault prior to playing to Vcds and I can’t seem to clear the fault (yellow exlimation mark)
does anyone know how I maybe able to?
Is it a distance issue because I didn’t do it infront of a wall?
scan prior to the ! Error
Code:
Thursday,16,January,2020,10:42:10:38378
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
Data version: 20190930 DS308.0
[URL='http://www.Ross-Tech.com']www.Ross-Tech.com[/URL]
VIN: WUAZZZ8V8H1900235   License Plate: VDJ
Mileage: 30693km-19071mi   Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 3C 42 44 47
          52 55 5F 65 6C A5 BB BC CF D6 D7
VIN: WUAZZZ8V8Hxxxxxxx   Mileage: 30693km-19071miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
29-Left Light -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (------DAZA)       Labels: None
   Part No SW: 8V0 907 404 A    HW: 07K 907 309 E
   Component: 2.5l R5/4V TF X22 0004
   Revision: 53X22000
   Coding: 0A250032246601033620
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM25TFS0118V0907404A 001005
   ROD: EV_ECM25TFS0118V0907404A.rod
   VCID: 373EE58C8ED86EF756-8062
2 Faults Found:
2967 - Intake Manifold Flap Position Sensor (Bank 1)
          P2015 00 [096] - Implausible Signal
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 30647 km
                    Date: 2020.01.09
                    Time: 06:41:16
                    Engine speed: 977.50 /min
                    Normed load value: 53.3 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 54 °C
                    Intake air temperature: 31 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 14.240 V
                    Unlearning counter according OBD: 39
                    Engine status: COENG_RUNNING
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
22858 - Bank 1; System Too Lean off Idle
          P2177 00 [096] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 30686 km
                    Date: 2020.01.15
                    Time: 15:06:10
                    Engine speed: 1885.00 /min
                    Normed load value: 11.4 %
                    Vehicle speed: 69 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: 48 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 13.860 V
                    Unlearning counter according OBD: 40
Readiness: 0010 0001
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0DL 300 012 E    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2012
   Revision: 00H06V07
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_001_VW37.rod
   VCID: 2B16C9FC4290DA1722-807E
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 8V0 614 517 C    HW: 8V0 614 517 C
   Component: ESC           H25 0621
   Revision: 00000000    Serial number: 60457000000313
   Coding: 2E9C938DD49913A98B930B6741966974C92BC8D1D08296771841500402A812
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   ROD: EV_Brake1UDSContiMK100IPB_035_VW37.rod
   VCID: 393AE3B4B8CC7887A0-806C
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0434627613
   Coding: 030C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002019
   ROD: EV_KessyHellaMQBAB_002.rod
   VCID: 3B36F9BCB2F04A97B2-806E
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-043.clb
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001178693
   Coding: 03100005110000001000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   ROD: EV_AirCondiFrontVaAU37X.rod
   VCID: 40CC8E50DB16294FE7-8014
   Relative humidity sensor in fresh air intake duct:
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: DE39839800PAG0MUFU03
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H34 0236
   Serial number: 02001707000536
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 017001
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EB030A8E1629FBFD5-802A
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 170104  043 0585
   Serial number:         170120134015
   Coding: 0A47F7
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0004
   Serial number: 62682398
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 19 12 2016  00000110
   Sensor For Anti Theft Alarm System:
   Subsystem 4 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY170233FEK
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000068854348
2 Faults Found:
262936 - Sensor for anti-theft alarm system
          B1330 29 [008] - Signal Implausible
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 14
                    Mileage: 30679 km
                    Date: 2020.01.14
                    Time: 14:50:26
558100 - Databus
          U1123 00 [008] - Received Error Message
          [Airbag_02 Datenbus empfangener Fehlerwert]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 14
                    Mileage: 28030 km
                    Date: 2019.10.29
                    Time: 10:13:27
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 A    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0038
   Serial number: 000308418617056
   Coding: 0470155011
   ASAM Dataset: EV_EPHVA18AU3700000 009031
   ROD: EV_EPHVA18AU3700000_009_VW37.rod
   VCID: 4AD8AC78ED2AE31F39-801E
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 3500E7C219FFC42474988055000026
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
2 Faults Found:
0790 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_MISALIGNMENT_HORIZONTAL]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 28030 km
                    Date: 2019.10.29
                    Time: 10:13:22
                    Control Module temperature: 26 °C
                    Voltage terminal 15: 13.3 V
                    Velocity_vehicle_reference: 0.00 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
                    Status_ACC_System: ACC_reversible_error
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_MISALIGNMENT_VERTICAL]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 28030 km
                    Date: 2019.10.29
                    Time: 10:13:22
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2R8B3.
   Coding: 98CCC000008000005C54000000C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002154
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 106C7E10CBF699CF37-8044
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 480 000 203 17
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000D4A400227
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 480 000 203 17
   Component: SideSensor_Pf  001 0887
   Serial number: 3580000000085918522D
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 480 402 502 17
   Component: SideSensor_Dr  000 6149
   Serial number: 3510001B5249E3B205F5
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 480 402 502 17
   Component: SideSensor_Pr  000 6149
   Serial number: 3520001B3249E3B5F6CK
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 480 401 601 17
   Component: FrontSensor_D  001 6149
   Serial number: 3550002BF23A3F821379
   Coding: 2D2D2D
3 Faults Found:
9440027 - Driver's side; side-airbag igniter
          B100B 1B [136] - Resistance Too High
          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 28030 km
                    Date: 2019.10.29
                    Time: 10:13:22
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [136] - Resistance Too High
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 28030 km
                    Date: 2019.10.29
                    Time: 10:13:22
9447189 - Seat Occupied Sensor; Passenger's Side
          B1027 15 [136] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 28030 km
                    Date: 2019.10.29
                    Time: 10:13:23
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 8V0 953 521 KT    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0140
   Revision: --------    Serial number: 04031704400169
   Coding: E818
   ASAM Dataset: EV_SMLSKLOMQB 020002
   ROD: EV_SMLSKLOMQB_020_AU37.rod
   VCID: 16600808E91277FF6D-8042
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790     HW: 8V0 920 790
   Component: FBenRDW       H14 0046
   Coding: 240D18D26E8800080184EC041000001000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 79BA23B4F84CB887E0-802C
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 C    HW: 3Q0 907 530 C
   Component: GW MQB High   515 5286
   Serial number: 07031710802273
   Coding: 030100043F0860005B008278380B00000001010000000000000000000000
   ASAM Dataset: EV_GatewNF 013020
   ROD: EV_GatewNF.rod
   VCID: 2F2EDDEC7688A6370E-807A
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20170221190108 22085
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
   Component: J367-BDMHella  H10 9070
   Serial number: 3062813204
1 Fault Found:
8521278 - Battery terminal recognition
          U1411 00 [008] - Open circuit
          [Spannung Fahrbatterie mechanischer Fehler]
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 13
                    Mileage: 29996 km
                    Date: 2019.11.22
                    Time: 16:59:09
                    Supply voltage: Terminal 30: 13.9 V
                    Terminal 15: On
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7756
   Serial number: HA1-00013.07.16
   Coding: 0601
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
   ROD: EV_AllWheelContrHA1VW37X.rod
   VCID: 45C29F44C4340C67D4-8010
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H06 0017
   ASAM Dataset: EV_LCMLeftCONTIAU426 001009
   ROD: EV_LCMLeftCONTIAU426_VW41.rod
   VCID: 42C88458D51A3B5FF1-8016
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 5Q0 905 861 A    HW: 5Q0 905 861 A
   Component: ELV-MQBA      H01 0120
   Revision: 00000000    Serial number: 17000610044004
   Coding: 5D00000000000000
   ASAM Dataset: EV_ELVMarquMQB 004111
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424D2809FAE85EF73-8060
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   ASAM Dataset: EV_LCMRightCONTIAU426 001009
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0410
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   ROD: EV_RearRadarS1BoschVW48X.rod
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 210217EBK25374
   Coding: 005D1A205C01040000001003
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 43C6815CCA003257FA-8016
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 K    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  506 5072
   Coding: 9107
   ASAM Dataset: EV_SteerAssisMQB 013144
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A38FCB8BDCA739FA9-806E
Address 47: Sound System (J525)       Labels:| 81A-035-466.clb
   Part No SW: 81A 035 466 A    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0420
   Revision: 00000001    Serial number: AUZ8ZAG5F006UB$
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 230621DC2A4012579A-8076
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 280217EBS17044
   Coding: 005D12205E01040000001003
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
Address 55: Headlight Range (J745)       Labels:* None
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Revision: --------    Serial number: --------------
   Coding: 0EEE00102B200200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU37.rod
   VCID: 3E30F0A8A1E25FBF95-806A
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 8V1 035 041 A    HW: 8V1 035 041
   Component: MU-P-LND-RW   053 0875
   Serial number: A838B0HS004349
   Coding: 017361080000000011511102000A00102F0028E6017001045E
   ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
   ROD: EV_MUHig6C3Gen2HBAS_AU37.rod
   VCID: 2D12C7E47C84D4273C-8078
   Data medium:
   Subsystem 1 - Part No SW: V03 959 802 DH    HW: -----------
   Component: ROW 2019  --- 0076
   Serial number: --------------------
   Display unit 1 for multimedia system:
   Subsystem 2 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9H1Y01TRL
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL120021700010736
   Compact Disc Database:
   Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 4011
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 8S0 907 273     HW: 4M0 907 273 B
   Component: RDKHUFAU736   H04 0002
   Serial number: 40000000001877
   ASAM Dataset: EV_RDKHUFAU736 002007
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 77BE258CCE58AEF796-8022
10 Faults Found:
8398082 - Tire Pressure Sensor(s)
          C111A 31 [009] - No Signal
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 222
                    Mileage: 30167 km
                    Date: 2019.11.23
                    Time: 17:44:34
                    Expanded ambient data 6-Vehicle speed: 123.57 km/h
                    Expanded ambient data 6-Outside air temperature: 23.50 °C
                    Tire pressure sensor 01-Manufacturer code: 0
                    Tire pressure sensor 01-Sensor identification number (sensor ID): 557572758
                    Tire pressure sensor 01-Wheel position: Unknown
                    Tire pressure sensor 01-CURRENT pressure: 0.00 bar
                    Tire pressure sensor 01-CURRENT temperature: -40 °C
                    Tire pressure sensor 01-SPECIFIED pressure: 0.00 bar
                    Tire pressure sensor 01-Warning pressure: 0.00 bar
8397058 - Front Left TPMS Sensor
          C1050 31 [008] - No Signal
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 29792 km
                    Date: 2019.11.22
                    Time: 08:33:25
                    Expanded ambient data 6-Vehicle speed: 16.19 km/h
                    Expanded ambient data 6-Outside air temperature: 25.50 °C
                    Left front tire pressure sensor: remaining oper. life: 127 m
                    Left front tire pressure sensor: identification-Manufacturer code: numerical value: no text
                    Left front tire pressure sensor: identification-Sensor identification number (sensor ID): 623977457
8397314 - Front Right TPMS Sensor
          C1051 31 [008] - No Signal
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 29792 km
                    Date: 2019.11.22
                    Time: 08:33:25
                    Right front tire pressure sensor: remaining oper. life: 127 m
                    Right front tire pressure sensor: identification-Manufacturer code: numerical value: no text
                    Right front tire pressure sensor: identification-Sensor identification number (sensor ID): 623978501
8397570 - Rear Left TPMS Sensor
          C1052 31 [008] - No Signal
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 29792 km
                    Date: 2019.11.22
                    Time: 08:33:25
                    Left rear tire pressure sensor: remaining oper. life: 127 m
                    Left rear tire pressure sensor: identification-Manufacturer code: numerical value: no text
                    Left rear tire pressure sensor: identification-Sensor identification number (sensor ID): 623977334
8397826 - Rear Right TPMS Sensor
          C1053 31 [008] - No Signal
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 29792 km
                    Date: 2019.11.22
                    Time: 08:33:25
                    Right rear tire pressure sensor: remaining oper. life: 127 m
                    Right rear tire pressure sensor: identification-Manufacturer code: numerical value: no text
                    Right rear tire pressure sensor: identification-Sensor identification number (sensor ID): 623977284
8389634 - TPMS Display
          C1239 F0 [009] - Position Determination Not Possible
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 218
                    Mileage: 30120 km
                    Date: 2019.11.23
                    Time: 13:47:00
                    Expanded ambient data 1-Left front tire pressure sensor: identification: Not available
                    Expanded ambient data 1-Right front tire pressure sensor: identification: Not available
                    Expanded ambient data 1-Left rear tire pressure sensor: identification: Not available
                    Expanded ambient data 1-Right rear tire pressure sensor: identification: Not available
8389633 - Adapatation Not Possible
          C112C 00 [009] - Tire Pressure Sensor(s) Defective or No Signal
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 220
                    Mileage: 30095 km
                    Date: 2019.11.23
                    Time: 10:29:49
                    Radio interference levels: 37
8390147 - Tire Pressure Monitoring
          C10DC 54 [008] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 30110 km
                    Date: 2019.11.23
                    Time: 13:36:54
8400898 - Tires 01: Tire  Pressure Warning
          C111B 00 [008] - Pressure too Low
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 28030 km
                    Date: 2019.10.29
                    Time: 10:13:21
                    Expanded ambient data 6-Vehicle speed: 0.00 km/h
                    Expanded ambient data 6-Outside air temperature: 21.00 °C
                    Expanded ambient data 2-Left front tire pressure sensor: nominal pressure: 2.60 bar
                    Expanded ambient data 2-Left front tire pressure sensor: actual pressure: Not available
                    Expanded ambient data 2-Left front tire pressure sensor: temperature: Not available
                    Expanded ambient data 2-Left front tire pressure sensor: identification: 623977457
8400901 - Tires 02: Tire  Pressure Warning
          C111D 00 [008] - Pressure too Low
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 28613 km
                    Date: 2019.11.04
                    Time: 05:47:44
                    Expanded ambient data 6-Vehicle speed: 19.57 km/h
                    Expanded ambient data 6-Outside air temperature: 10.50 °C
                    Expanded ambient data 3-Right front tire pressure sensor: nominal pressure: 2.60 bar
                    Expanded ambient data 3-Right front tire pressure sensor: actual pressure: 2.10 bar
                    Expanded ambient data 3-Right front tire pressure sensor: temperature: 12 °C
                    Expanded ambient data 3-Right front tire pressure sensor: identification: 623978501
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H12 0231
   Coding: 0273010102002001400040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 27021711P21885
   Coding: 0403070100000101010223468048A90080000E200020
   ASAM Dataset: EV_MFKBoschMQBB 001001
   ROD: EV_MFKBoschMQBB_VW46.rod
1 Fault Found:
0665 - Module for Camera
          C110A F0 [008] - Limited Visibility
          [Permanent_blindness_detected]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 101
                    Reset counter: 0
                    Mileage: 29039 km
                    Date: 2019.11.06
                    Time: 17:14:33
                    Control Module temperature: 45 °C
                    Outside air temperature: 23.0 °C
                    Vehicle speed: 43.23 km/h
                    System run time: 1484.0 s
                    Voltage terminal 15: 14.2 V
                    mid: 01 12
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0041
   Serial number: 240117EAO07897
   Coding: 000C12204001040000001002
   ASAM Dataset: EV_DCURearDriveMINKLO 006003
   ROD: EV_DCURearDriveMAXCONT.rod
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      020 0041
   Serial number: 240117EAO07894
   ASAM Dataset: EV_DCURearPasseMINKLO 006003
   ROD: EV_DCURearPasseMAXCONT.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 D    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
   ROD: EV_RearRadarS2BoschVW48X.rod
   VCID: 3620E88889D297FF4D-8062
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
   Component: LED1L         H09 0008
   ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
   ROD: EV_LEDModLeftMELCOAU736_VW37.rod
   VCID: 177E050CEE184EF776-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H09 0008
   ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----(Elapsed Time: 01:58, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
The below is the scan post playing with ACC (I'll put in below exactly what I did in a minute)
Code:
Saturday,18,January,2020,17:23:11:38378
www.Ross-Tech.com
VIN: WUAZZZ8V8Hxxxxxxx   License Plate: dfee
Mileage:    Repair Order: Acc2
                Address 13: Auto Dist. Reg       Labels: 3Q0-907-572.clb
Control Module Part Number: 5Q0 907 572 G    HW: 5Q0 907 572 G
  Component and/or Version: ACC BOSCH MQB H10 0571
           Software Coding: 3500E7C219FFC42474988055000026
            Work Shop Code: WSC 06385 790 00016
              ASAM Dataset: EV_ACCBOSCHVW416 001005 (AU37)
3 Faults Found:
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_ALIGNMENT_NOT_OK]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 237
                    Mileage: 30821 km
                    Date: 2020.01.18
                    Time: 17:18:36
                    Control Module temperature: 51 °C
                    Voltage terminal 15: 11.9 V
                    Status_ACC_System: ACC_irreversible error
          C1103 00 [009] - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 237
                    Mileage: 30821 km
                    Date: 2020.01.18
                    Time: 17:18:36
          C1103 00 [009] - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 237
                    Mileage: 30821 km
                    Date: 2020.01.18
                    Time: 17:18:36
Hopefully the above worked...
Anyhow anyone have any idea how I may be able to get rid of the exclamation mark!?
Note it wasn’t there prior to me dicking around - neither were those errors in the attached above - just the ACC standard error.
I’ll copy the full prior lot tomorrow and post log
For bonus points ideas on how to get the ACC to work without a dealer... haha but I might just get the dealer to do it.
Code:
Saturday,18,January,2020,17:22:35:38378
www.Ross-Tech.com
VIN: WUAZZZ8V8xxxxxx   License Plate: xx
Mileage:    Repair Order: ACC
                Address 01: Engine       Labels: None
Control Module Part Number: 8V0 907 404 A    HW: 07K 907 309 E
  Component and/or Version: 2.5l R5/4V TF X22 0004
           Software Coding: 0A250032246601033620
            Work Shop Code: WSC 92521 052 00000
              ASAM Dataset: EV_ECM25TFS0118V0907404A 001005 (AU37)
1 Fault Found:
17156 - Databus
          U1123 00 [039] - Received Error Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Mileage: 30821 km
                    Date: 2020.01.18
                    Time: 17:19:47
                    Engine speed: 742.00 /min
                    Normed load value: 15.7 %
                    Coolant temperature: 88 °C
                    Intake air temperature: 69 °C
                    Voltage terminal 30: 13.980 V
                    Drivetrain coordinator: ACC fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake function status-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
Readiness: 1010 0001
The above is the new error I see (which has brought up the yellow exclamation mark!
Compared to the Full auto scan above (as the car is tuned I get the lean issue - but it clears when reset).
As I said the above is new since Iwas looking at some options in module 13
Bit sketchy with the 1st post.
So all I can glean from it is
You’ve fitted a new IC and the ACC sensor isn’t quite right upon reassembly of the bumper ?
It can be a fraction out and bring up an error so you’ll need a recalibration at a dealer that can actually do it.
VCDS or alike won’t help you at all.
Basically the summary I was after...
I wasn’t sure if I had read people moving it and it resetting - coming good.
But the bigger part was the exclamation mark that’s appeared from being in VCDS...
Depends on how far out it is
You could spend ages and still not have it in the correct position.
VCDS will not help to clear the fault.
There’s a procedure and a special board needed for calibration.
When I retrofitted the ACC to my SQ5, I manually calibrated the sensor from the measuring blocks / basic settings in vcds. So yes you can with a bit of patience adjust the sensor.
You do need to drive for a few miles inbetween each adjustment to work out the turns on the screws, but 5 months on and it's still faultless.
When it goes out of sync, you also do need to reset it in basic settings, clearing fault codes won't reset it iirc
Reactions: random101
Convince feature as well as safety system. For the sake of yourself and others get it calibrated correctly:
Well, if I can get it working by making some small adjustments - it’ll save me a small fortune.
It needs to go into the dealer for the pedestrian recall... so they’ll do it properly but if I can get rid of the fault in VCDS that’s what I want to achieve in this post...
The dealer will see the error on the VC though straight away and know somethings amiss....
If they spot the IC then they'll be reluctant to do anything for free/under warranty.
There is every chance that they might complete the calibration as part of other works, give a trainee tech some experience or something, but the kit needed costs a lot and not every dealership has it, so I would not count on it if they need to sub the work out.
Important thing to remember here is that the vehicles safety systems also use this sensor so it would be a good idea, both for yourself and others, to make sure the works are done correctly for piece of mind.
Reactions: random101, Dan_DJT and 8YARWY
T
761
T-800
T
724
949
