Airbag light an MOT fail?
B
Benisere
Guest
So i had a sticky heater fan took out the glove box and had to disconnect the airbag isolator for the passenger seat, fixed the fan now the airbag light is on. Will this fail the MOT if so does anyone know how much it will cost to get the AUDI garage to check and turn off?
Ben
Pretty sure its an MOT fail, I dont know what Audi charge to remove this but you could track someone down with Vag com they would be able to wipe it
just did a quick check and it is! grr only a fairly recent change to the law as well...
yeah that sucks but most garages can clear the code - I tihnk there is a Vag com list on the forum somewhere but not sure as im quite new!
Just get vag com not expensive Ross tech and save bucks mate
ill see if anyone local has got it for the time being just need it done before the mot
If you want to drive down as far as Sandbach Services I can reset it for you, if you can't find anyone more local.
518
922
740
