Graeme71
I have a 2010 A6 C6 Allroad Quattro 3L TDI and have just had the suspension valve block replaced as it was faulty. However the suspension will now not re-calibrate and the function on the MMI to alter the height of the car does not now work at all. and I cannot switch the jacking mode off. I have the two fault lights lit constantly on my Dashboard. Everything works, the compressor etc and there are no leaks at all. Also the ESP button no longer works, if I press it the light appears on the dash but disappears as soon as I release the button. The mechanic says I need to replace the SVM. About 6 months ago I did upgrade the MMI firmware and satnav maps to the latest version from upgrademyaudi. Pictures attached showing the faults from VCDS. Any ideas before I take it to Audi and get charged a fortune? Cheers.
