Hello to all!
I have a 2010 A3 sportback, 09/2009 built.
With the 3 plug BCM unit.
I am considering installing the original anti-theft system. (yes there is not standard from the factory)
I am just doing an initial research right now.
If someone has done it, I would appreciate any info.
From my search, I found that is needed:
Is it better to retrofit the oem solution or install an after matket alarm?
Best regards,
George
- siren (under the hood)
- control unit for anti-towing device and anti-theft device (behind glove box)
- movement detector (in the lights cluster)
- warning lamp
- micro switch (in hood lock)
- button for deactivation of anti-theft system and tow-away protection (on door)
- all cabling needed for the above
Best regards,
George
