Hi guys
I have managed to locate the speaker sizes and places for my non bose 10 speaker sound system.
Has anyone upgraded their and what speakers did you use?
Where is the amplifier location?
will upgrading the 4 x doors to 2 ways or equivalent better quality speakers make a improvement?
Some advice I have had
Leave everything as it is, as the amp is not powerful enough to drive anything more than what's fitted and just upgrade the tweeters.
I have sourced a amplifier that's a direct replacement for what's installed, it claims you remove old amp and plug this one straight in
specs below
Output power RMS / max.
- @ 4 Ohms 4 x 35 / 70 Watts (Font/Rear channels)
- @ 2 Ohms 4 x 50 / 100 Watts (Font/Rear channels)
- @ 1 Ohm -
- bridged @ 4 Ohms -
- bridged @ 2 Ohms -
- Subwoofer output @ 4 Ohms -
- Subwoofer output @ 2 Ohms 1 x 160 / 320 Watts (4 channels each 40 / 80 Watts)
Amplifier technology Class AB
Inputs 4 x Highlevel speaker input
1x MEC
1 x Remote In
Input sensitivity Highlevel 5 - 11 Volts
Input impedance RCA / Cinch -
Input impedance highlevel 13 Ohms
Outputs 8 x Speaker output
2 x RCA / Cinch
1 x Remote Out
Output voltage RCA / Cinch 3 Volts RMS
Frequency response 20 Hz - 22,000 Hz
DSP resolution 56 Bit
DSP power 172 MHz
Sampling rate 48 kHz
DSP type Audio signal processor
Signal converters A/D: BurrBrown
D/A: BurrBrown
Any input gentlemen?
Regards
Slapz
Signal-to-noise ratio digital input -
Signal-to-noise ratio analog input 103 dB (A-weighted)
Distortion (THD) < 0.01 %
Damping factor > 100
Operating voltage 10.5 Volts (max. 5 sec.down to 6 Volts)
Current draw 670 mA
Max. remote output current 500 mA
Fuse 1 x 20 A Maxi-fuse (APX)
Additional features Variable input sensitivity, fully stabilized internal power supply with Start-Stop capability, 56 Bit digital signal processing, internal memory for 2 different sound setups, USB input, ADEP.2 circuit, Auto Remote switch, MEC slot, input for optional remote control, stereo line outputs with balanced output transformers (floating ground)
Dimensions (H x W x D) 44 x 185 x 139 mm /
1.73 x 7.28 x 5.47“
specs below
- @ 1 Ohm -
1x MEC
1 x Remote In
2 x RCA / Cinch
1 x Remote Out
DSP power 172 MHz
D/A: BurrBrown
Regards
Slapz
Current draw 670 mA
1.73 x 7.28 x 5.47“
