Anyone have 2014 maps?
allanmb
Does anyone have 2014 maps on their A4? I think that would be map version 6.17.3. I want to find out if a little bug has been fixed in the software, and if so, try and wangle a free upgrade ;-)
razza1
What's the bug?
allanmb
The fairly well known random play bug. If you have music on usb or sd card, select random play, it never remembers random when you turn the ignition off. Instead it will revert to consecutive order.
sidibear
Going with the flow.
Staff member
Moderator
Mine has always done that and I have 2014 map, but mine is a B7 with mk1 so its probably not helpful.
razza1
Really? Guess it was about time they did that, it's the only thing that bugs me about the nav in the audis
Zobware
Not sure if this is true but dealer told me only cars from 2013 onwards have 7 digit postcode even if you get the latest maps
allanmb
I think MMI 3G and 3G+ do 7 digit postcodes, but 2G doesnt
Anees
My car is a late 2009 with MMI 3G+ (Tech Pack High - have the two 2D cards and SIM card slot with HDD etc) Does this mean that if I bought updated 2014 maps I should hopefully get 7 digit post codes?
Its pretty poor that it doesn't support them as standard; even on a 2009 car!
Anees
Richh999
My 2012 facelift car has 7 digit postcodes, not sure if it was updated but it is running 3G+ MMI..
beemerboy9
The 7-digit postcode search is nothing to do with the maps and everything to do with the type of firmware that is running on the Navigation device.
Hazzydayz will put non-standard firmware (not intended for a 5-digit postcode car so not a question of simple up-versioning) on your car at the same time as a map update.
I am very pleased with their work.
