Arm rest
edthebal
Glasgowish
I have managed to get my hands on an armrest from a 2007 model s-line will this fit a b6 ,the arm rest is complete apart from the bracket that goes from armrest to body this is broken ,,the reason i ask is i dont see any particular place for this to go ????any help would result in you winning the lotto Lol thanks in advance >>Ed
When installing the armrest you will need to remove the ash tray at the back of the hand brake. 3x nut's will have tobe removed then you will have to insert the bracket (so yes you will require a bracket) .This is then bolted into place, using the 3 nut's. The bracket is the most important piece of the armrest as it will provide the support/strenght.
That means its probably foo-bar'd, when I retro-fitted my arm-rest, I had to cut a hole in the plastic using a template that was provided.
I may have a spare bracket if you need one. When i bought mine, i found i had a bracket already.
499
820
594
682
