AUDI A3 8l 3.2
RS4B5
5 pots
Now that the r32 project is finished all I have left is a vision and a 8l a3 long story short I want to strip it 3.2 vr6 in and Quattro any advice appreciated and what Il need
Tj 0785
Well-Known Member
Are you starting with a a3 Quattro or wanting to fit the Quattro? Makes no sense try’s to retro fit a Quattro system time and cost wise be better to sell the a3 and start with a Quattro one
IPG
So you will run 3.2 as FWD?
IPG
From quattro to quattro is fairly straightforward.
you'll need
- vr6 clutch housing (the gearbox housing is the same)
- ideally the vr6 bevel box
- vr6 bellhousing to block bolts
- obviously the engine (long block w/all coolant lines inc. from heater core, all vacuum system lines, intake etc.)
- the engine brackets (gearbox brackets are the same)
- vr6 engine wiring loom + the bit that plugs in at the rain tray to join to the interior harness
- vr6 ecu
- vr6 accessories bracket
- vr6 exhaust
From FWD to quattro .... well have fun with that
IPG
it'll be much less of a headache and you can actually focus on what needs to be done instead of making something that can already be bought for much less hassles, effort, time et.
